[GRASS-web] Slovakia mirror
    Markus Neteler
    neteler at osgeo.org
    Mon Mar 23 16:51:08 EDT 2009
Hello Pavol,
I see that http://grass.sk/index.php
is lagging behind for 3 days... maybe you need to read from grass.osgeo.org?
The rsync server responds well.
Best regards,
Markus
On Sun, Mar 22, 2009 at 12:18 PM, Pavol Cvengros
<pavol.cvengros at primeinteractive.net> wrote:
> Hello,
> rsync server on my server is set. Only one repository available from sync
> and that is grass. Maximum 20 parallel connections.
> Please test it and if everything will be ok I would like to apply for tier 1
> mirror server.
> Rsync server: grass.sk
> Best regards,
> Pavol
> On 11. 3. 2009 9:22, Markus Neteler wrote:
> Hello Pavol,
> On Wed, Mar 11, 2009 at 7:48 AM, Pavol Cvengros
> Hello,
> I am running Slovakia mirror on my private server with courtesy of Prime
> Interactive Ltd. for a long time on domain grass.sk
> I found that you are looking for tier 1 mirrors. What is needed to become
> one? Is the only one condition to run rsync server to provide mirroring
> capabilities for tier 2 server?
> that's right! Just "be open", say, permit others to rsync from you.
> All this originates from the times that the master site was grass.itc.it
> with
> limited bandwiths. grass.osgeo.org is well connected (thanks to
> telascience.org)
> so that we reach 2.x TB (!) peaks per months.
> However, mirrors don't harm and we prefer a semi-decentralized
> infrastructure
> in case the North Atlantic or Pacific network bones get cut. Still we'd
> remain
> online :)
> If you have enough bandwidth you may enable others to rsync from you.
> Then please ping us here to update the mirror list (next of your mails will
> go through directly).
> Best regards,
> Markus
More information about the grass-web
