[GRASS-web] Slovakia mirror
Pavol Cvengros
pavol.cvengros at primeinteractive.net
Sun Mar 22 07:18:15 EDT 2009
Hello,
rsync server on my server is set. Only one repository available from
sync and that is grass. Maximum 20 parallel connections.
Please test it and if everything will be ok I would like to apply for
tier 1 mirror server.
Rsync server: grass.sk
Best regards,
Pavol
On 11. 3. 2009 9:22, Markus Neteler wrote:
> Hello Pavol,
> On Wed, Mar 11, 2009 at 7:48 AM, Pavol Cvengros
> <pavol.cvengros at primeinteractive.net> wrote:
>> Hello,
>> I am running Slovakia mirror on my private server with courtesy of Prime
>> Interactive Ltd. for a long time on domain grass.sk
>> I found that you are looking for tier 1 mirrors. What is needed to become
>> one? Is the only one condition to run rsync server to provide mirroring
>> capabilities for tier 2 server?
> that's right! Just "be open", say, permit others to rsync from you.
> All this originates from the times that the master site was grass.itc.it with
> limited bandwiths. grass.osgeo.org is well connected (thanks to telascience.org)
> so that we reach 2.x TB (!) peaks per months.
> However, mirrors don't harm and we prefer a semi-decentralized infrastructure
> in case the North Atlantic or Pacific network bones get cut. Still we'd remain
> online :)
> If you have enough bandwidth you may enable others to rsync from you.
> Then please ping us here to update the mirror list (next of your mails will
> go through directly).
> Best regards,
> Markus
URL: http://lists.osgeo.org/pipermail/grass-web/attachments/20090322/ef8ad6d5/attachment.html
More information about the grass-web
