[GRASS-web] importing multiples las files in grass gis (windows)
Markus Neteler
neteler at osgeo.org
Sun Apr 13 12:53:20 PDT 2014
Hello Rengifo Ortega,
please note that this is a perfect question for the grass-user mailing list:
http://lists.osgeo.org/mailman/listinfo/grass-user
(here you are on the Web site list).
Some quick answers below:
On Fri, Apr 11, 2014 at 10:38 PM, Rengifo Ortega <rengifoo at yahoo.de> wrote:
> Hello dear grass developers
> I am currently working with a project, where I need to build a DEM with a
> 2x2 meters resolution. I have around 800 las files with 0.7 and 2
> points/sqm, which I already converted to text format using the las2txt
> command as explained at liblas.org.
Hint:
You may just remain in LAS/LAZ format when switching to GRASS GIS 7,
there are now r.in.lidar and v.in.lidar.
http://grass.osgeo.org/grass70/manuals/r.in.lidar.html
http://grass.osgeo.org/grass70/manuals/v.in.lidar.html
> So, I intend to import all 800 .txt files into GRASS GIS at once, if
> possible, in order to create my DEM from the entire area of study.
> However, every time I try to import even one txt file in Grass Gis, by
> using the r.in.ixyz , I get the well- known allocation memory message
> (ERROR: G_calloc: unable to allocate.... )
GRASS GIS 7 is now "large file" capable also for vector data. The only
limitation per map is 2^31 - 1 (about 2 billion) features per vector
map (see
http://grasswiki.osgeo.org/wiki/GRASS_GIS_Performance#Vector_geometry
See also
http://grass.osgeo.org/news/32/15/GRASS-GIS-7-0-0-beta1/
http://trac.osgeo.org/grass/wiki/Release/7.0.0beta-News
> So, wrapping all together what I want to do is:
> 1) To import all 800 files at once, instead of importing one by one. I
> know it is possible in linux, but I have not figured it out how to do it in
> the cmd (dos) windows.
You are at time
- limited by GRASS GIS 6
- limited due to the absence of r.in.lidar and v.in.lidar in G6.
Hence pls consider to try the new version.
> Technical settings of my work environment:
> Grass GIS 6.4 running on windows 7, installed using the osGeo4W installer,
> fully operative.
> RAM 6GB
> The las data is over 750 GB. Lasdata was pre-processed using lastools. Only
> class 2 (bare ground) was kept.
> I hope someone can drop some lines about how to do this in a windows
> environment. So, far I only found linux examples, which uses eval, flags
> and pipes. All this is not applicable in cmd.
Indeed, that's why r.in.lidar and v.in.lidar have been developed.
Regards,
Markus Neteler
http://courses.neteler.org/
http://gis.cri.fmach.it/
More information about the grass-web
