[GRASS-web] Need Assistance
rushil.agarwal at wipro.com
Mon May 12 21:30:17 PDT 2014
Hi Markus,
Thanks for the reply. I tried the same but the problem still persist.
I used this command:
[cid:image001.png at 01CF6E91.B4D98020]
After this again it ask for confirming the mapset and location.
[cid:image002.jpg at 01CF6E92.224A9EF0]
PFA Grassrc6 file if any change required in the file.
Thank & Regards,
Rushil
From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On Behalf Of Markus Neteler
Sent: Tuesday, May 13, 2014 12:30 AM
To: Rushil Agarwal (WT01 - ENU)
Cc: GRASS-web
Subject: Re: [GRASS-web] Need Assistance
Hi Rushil
you can achieve this in GRASS 6 by also adding the path to the start script as a parameter. Then it will start the session right away:
Something like:
grass643 C:\Users\ru281187\Documents\grassdata\demolocation\PERMANENT
Other option: in GRASS GIS 7 this text menu no longer exists (only a graphical user interface), so in -text mode GRASS will load the location/mapset from the last session.
hope this helps
Markus
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments.
WARNING: Computer viruses can be transmitted via email. The recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email.
www.wipro.com
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20140513/4edd1ee3/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20140513/4edd1ee3/attachment-0001.png>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20140513/4edd1ee3/attachment-0001.jpg>
Type: application/octet-stream
Desc: grassrc6
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20140513/4edd1ee3/attachment-0001.obj>
More information about the grass-web
