[GRASS-web] Probleme beim Transformieren von Koordinaten
Schütz SC
maik.schuetz at sc-ing.de
Thu Aug 31 00:42:18 PDT 2017
OK, I'm sorry.
My answer once more with the mailing list in Cc. Best regards, Maik Schütz
-----Ursprüngliche Nachricht-----
Von: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] Im Auftrag von Markus Neteler
Gesendet: Mittwoch, 30. August 2017 23:47
An: Schütz SC
Betreff: Re: [GRASS-web] Probleme beim Transformieren von Koordinaten
Dear Mr. Schütz,
please be so kind to keep the mailing list in cc - at time I am unable to quickly help with the issue and probably our other developer is able to help.
Best regards,
Markus Neteler
On Tue, Aug 29, 2017 at 8:31 AM, Schütz SC <maik.schuetz at sc-ing.de> wrote:
> Dear Mr. Neteler,
> thank you very much for your answer.
> Example: the coordinate of the lighthouse of the isle Hiddensee
> DHDN (Bessel), Gauß-Krüger-4: 4572445.6 6052741.1;
> “m.proj” convert it with my “3. try” (last e-mail): 33378616.33
> 6051779.33;
> correct is: 33378506 6051816 (source: https://www.deine-berge.de/Rechner/Koordinaten/Dezimal/55.012786,13.235480).
> I use GRASS GIS 7.2.1 with the integrated PROJ.4 Version.
> Thank you.
> Mit freundlichem Gruß / Kind regards
> Maik Schütz
> Schuldt Consult Ingenieurgesellschaft mbH Alte Richtenberger Straße 31
> D-18437 Stralsund
> Phone: +49 (0) 38 31 - 61 29 25
> Fax: +49 (0) 38 31 - 61 29 99
> mail to: maik.schuetz at sc-ing.de
> Sitz der Gesellschaft: Stralsund HRB 4483
> Geschäftsführung: Carsten Schuldt
> Gesendet: Donnerstag, 24. August 2017 10:08
> An: Schütz SC
> Cc: GRASS-web
> Dear Mr Schütz,
> this shift is typical for a datum error - would you mind to send a test point with expected result?
> Furthermore, which GRASS GIS and PROJ.4 versions do you use?
> Best regards,
> Markus Neteler
> Markus Neteler, PhD
> http://www.mundialis.de - free data with free software
> http://grass.osgeo.org http://courses.neteler.org/blog
> 2017-08-22 13:09 GMT+02:00 Schütz SC <maik.schuetz at sc-ing.de>:
>> - english version below -
>> Sehr geehrte Damen und Herren,
>> ich habe noch keine großen Erfahrungen mit Ihrer Software und hoffe,
>> Sie können mir weiterhelfen.
>> Ich habe eine Koordinatendatei coordinates.txt in Bessel (DHDN),
>> Gauß-Krüger-4 und möchte die Koordinaten nach wgs84, UTM33 transformieren.
>> Ich versuchte es mit: m.proj
>> 1. Versuch:
>> proj_in:”+proj=tmerc +name=tmerc +a=6377397.155 +es=0.0066743720
>> +lat_0=0.0
>> +lon_0=12.0 +k=1.000035 +x_0=4500000.0”
>> proj_out:”+proj=utm +name=utm +a=6378137.0 +es=0.006694380 +zone=33
>> +unfact=1.0”
>> 2. Versuch:
>> proj_in:“+proj=tmerc +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0
>> +ellps=bessel +datum=potsdam +units=m“
>> +unfact=1.0”
>> 3. Versuch:
>> proj_in:”+proj=tmerc +lat_0=0 +lon_0=12 +k=1.000035 +x_0=4500000
>> +y_0=0
>> +towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.7”
>> +unfact=1.0”
>> Die Berechnung funktioniert auch, aber sie ist ungenau. Die
>> Koordinaten sind
>> 50 bis 100 m von der „genauen“ Lage entfernt. Ich habe alles möglich
>> versucht, aber es wird nicht genauer.
>> Gibt es noch einen anderen Weg, die Koordinaten in GRASS GIS genauer
>> zu transformieren?
>> Ich danke Ihnen sehr für Ihre Hilfe.
>> Maik Schütz
>> D-18437 Stralsund
>> Problems with transforming coordinates
>> Dear Ladies and Gentlemen,
>> I’m not an expert in programming and hope, you can help me.
>> I’ve got a coordinates.txt with coordinates in Bessel (DHDN), Gauß-Krüger-4.
>> I want to transform the coordinates into wgs84, UTM33 (region:
>> Northeast Germany / Baltic Sea).
>> I tried it with m.proj:
>> 1. Try:
>> +lat_0=0.0
>> +unfact=1.0”
>> 2. Try:
>> +unfact=1.0”
>> 3. Try:
>> +y_0=0
>> +unfact=1.0”
>> It works, but it is vague. The coordinates are ~ 100.0 m far away
>> from the right place. I tried many options, but it didn’t function correct.
>> Is there another possibility, to transform the coordinates more
>> correct in GRASS GIS?
>> Thank you for your help.
>> grass-web mailing list
>> grass-web at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-web
Markus Neteler, PhD
http://www.mundialis.de - free data with free software http://grass.osgeo.org http://courses.neteler.org/blog
More information about the grass-web
