[GRASS-web] Grass GIS
Luciana Caporaletti lovethewildearth at gmail.com
Mon Jun 26 11:35:34 PDT 2017
I have been trying to use Grass on my Mac for four hours now.  I've
downloaded every possible framework to make it work, but every time I
double click on the icon, I get error messages.
Last login: Mon Jun 26 11:33:07 on ttys000
'/Applications/GRASS-7.0.app/Contents/MacOS/grass.sh'; exit
Katrinas-MacBook-Pro:~ katrinaroman$
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.7.10 found.
Starting GRASS GIS...
dyld: Library not loaded: /usr/local/lib/libintl.8.dylib
  Referenced from:
/Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.5.dylib
  Reason: image not found
  File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/gis_set.py", line
31, in <module>
    from core import globalvar
  File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/globalvar.py",
line 29, in <module>
    from core.debug import Debug
  File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/debug.py",
line 72, in <module>
    Debug = DebugMsg()
  File
line 37, in __init__
    self.SetLevel()
  File
line 43, in SetLevel
    self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
  File
"/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/script/core.py",
line 935, in gisenv
    s = read_command("g.gisenv", flags='n')
  File
line 443, in read_command
    process = pipe_command(*args, **kwargs)
  File
line 418, in pipe_command
    return start_command(*args, **kwargs)
  File
line 356, in start_command
    if debug_level() > 0:
  File
line 1519, in debug_level
    _debug_level = int(gisenv().get('DEBUG', 0))
  File
line 935, in gisenv
  File
line 446, in read_command
    return handle_errors(returncode, stdout, args, kwargs)
  File
line 313, in handle_errors
    returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['g.gisenv', '-n']
ended with error
Process ended with non-zero return code -6. See errors in the (error)
output.
Error in GUI startup. If necessary, please report this error to the GRASS
developers.
Switching to text mode now.
Hit RETURN to continue...
  File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 1461, in
<module>
    set_data()
  File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 682, in
set_data
    gui_startup(grass_gui == 'gtext')
  File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 704, in
gui_startup
    os.execlp(cmd_name, "-text")
  File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.py",
line 329, in execlp
    execvp(file, args)
  File
line 346, in execvp
    _execvpe(file, args)
  File
line 382, in _execvpe
    func(fullname, *argrest)
OSError: [Errno 2] No such file or directory
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
I would really like to use your program.  Please help!
Thank you,
Luciana Caporaletti
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20170626/1f1ed04c/attachment.html>
More information about the grass-web mailing list
