[GRASS-web] The New version
Helmut Kudrnovsky hellik at web.de
Sat Nov 18 07:22:09 PST 2017
IBRAHIM IBRAHIM wrote
> Dear Mr. Helmut
>  i don't know if i didn't get what this web page is trying to say or its
> something different than what i need but just to clear things up i have
> about 100 commands that i want to run consecutively and i'm not an expert
> in using grass gis (i know 5-7 commands only) so what is the easiest way
> to
> run my code ?
> Thanks In Advance
> On Fri, Nov 10, 2017 at 5:17 PM, IBRAHIM IBRAHIM <
> ibra.alwafa@
> wrote:
>> Thank you very much for the super efficient and very fast help !!!!!!
>> On Fri, Nov 10, 2017 at 5:15 PM Helmut Kudrnovsky <
> hellik@
> > wrote:
>>> yes it is:
>>> https://grasswiki.osgeo.org/wiki/GRASS_and_bat-files_in_windows_console
>>> Kind regards
>>> Helmut
>>> Am 10.11.17, 14:10, Markus Neteler <
> neteler@
> > schrieb:
>>>> Hi Helmut,
>>>> do you have a hint for us? Maybe it is already explained... Thanks!
>>>> Mobile greetings,
>>>> Markus
>>>> On Nov 10, 2017 11:10 AM, "IBRAHIM IBRAHIM" <
> ibra.alwafa@
>>>> wrote:
>>>>> Thank you very much that was super help full !!! ....... one final
>>>>> question in the 6.4 version i used to write my code in Notepad and
>>>>> save it
>>>>> as ".bat" then i use the "sh" command to run it but i seems not to
>>>>> work on
>>>>> 7.2 version
>>>>> thanks in advance
>>>>> On Fri, Nov 10, 2017 at 1:06 AM, Markus Neteler <
> neteler@
>>>>> wrote:
>>>>>> Dear
>>>>>> On Thu, Nov 9, 2017 at 3:47 PM, IBRAHIM IBRAHIM <
> ibra.alwafa@
>>>>>> wrote:
>>>>>> > Dear GRASS Development Team
>>>>>> > I used to use Grass 6.4.2 and some times its very slow and doesn't
>>>>>> show the
>>>>>> > full map when i do d.rast so i decided to use Grass 7.2.0 but
>>>>>> unfortunately
>>>>>> > i couldn't find the command r.los is it there with a different name
>>>>>> of its
>>>>>> > removed ?
>>>>>> yes, it got a different, more understandable name: r.viewshed. And it
>>>>>> got WAY faster!
>>>>>> For a lookup table, see
>>>>>> https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Renamedmodules
>>>>>> Regards,
>>>>>> Markus Neteler, PhD
>>>>>> http://www.mundialis.de - free data with free software
>>>>>> http://grass.osgeo.org
>>>>>> http://courses.neteler.org/blog
> grass-web mailing list
> grass-web at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-web
the wiki example shows the content of a windows batch file (e.g.
yourscript.bat).
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Website-f4053612.html
More information about the grass-web mailing list
