[GRASS-web] Error r. diversity
    Markus Neteler
    neteler at osgeo.org
    Thu Oct  4 06:13:37 PDT 2018
On Thu, Oct 4, 2018 at 5:06 AM Quynh Chau <quynhchau0709 at gmail.com> wrote:
> Hi,
> My name Quynh, I'm new to GRASS GIS and have a problem executing the r.diversity function via GRASS 7.4.0
> When running r.diversity for NDVI from worldview 3 image,I get the following error:
> Process ended with non-zero return code -1073740940. See errors in the (error) output.
Can you please try as explained here (g.list example there, you would
need to use your r.diversity command:)
https://grasswiki.osgeo.org/wiki/WinGRASS_errors#The_GRASS_GIS_exits_when_started_with_g.list_CalledModuleError_and_-1073741511_return_code
and report back?
Unfortunately I have no idea how to decode the error code
automatically but from similar reports (unanswered so far) I see it is
hex 374:
- https://gis.stackexchange.com/questions/247558/pyqgis-standalone-app-process-finished-with-exit-code-1073740940-0xc0000374
- https://stackoverflow.com/questions/43985060/process-finished-with-exit-code-1073740940-0xc0000374-python
>From here I see
https://social.technet.microsoft.com/Forums/windows/en-US/578396fd-29c0-4dd3-b002-5e2e8df1b398/exception-code-0xc0000374?forum=w7itprogeneral
--> exception code 0xc0000374 indicates a heap corruption
which is discussed here:
https://social.microsoft.com/Forums/Azure/en-US/2b2d5d37-ff69-481e-aab2-5b29e2801941/wpf-process-crashing-with-error-code1073740940?forum=Offtopic
--> https://stackoverflow.com/questions/1010106/how-to-debug-heap-corruption-errors
Question to you: could you provide a small example with dataset?
Regards,
Markus
Markus Neteler, PhD
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
More information about the grass-web
