[GRASS-web] Error r. diversity
Quynh Chau
quynhchau0709 at gmail.com
Wed Oct 10 19:46:23 PDT 2018
Thank you for your help.
I have got out the links you have submitted and try some ways. But that
cannot fix the problem.
Here is a small example of NDVI map from worldview 3. I hope it can help
you figure out how to fix the problem
Best,
Quynh
Vào Th 5, 4 thg 10, 2018 vào lúc 20:13 Markus Neteler <neteler at osgeo.org>
đã viết:
> Hi,
> On Thu, Oct 4, 2018 at 5:06 AM Quynh Chau <quynhchau0709 at gmail.com> wrote:
> > Hi,
> > My name Quynh, I'm new to GRASS GIS and have a problem executing the
> r.diversity function via GRASS 7.4.0
> > When running r.diversity for NDVI from worldview 3 image,I get the
> following error:
> > Process ended with non-zero return code -1073740940. See errors in the
> (error) output.
> Can you please try as explained here (g.list example there, you would
> need to use your r.diversity command:)
> https://grasswiki.osgeo.org/wiki/WinGRASS_errors#The_GRASS_GIS_exits_when_started_with_g.list_CalledModuleError_and_-1073741511_return_code
> and report back?
> Unfortunately I have no idea how to decode the error code
> automatically but from similar reports (unanswered so far) I see it is
> hex 374:
> https://gis.stackexchange.com/questions/247558/pyqgis-standalone-app-process-finished-with-exit-code-1073740940-0xc0000374
> https://stackoverflow.com/questions/43985060/process-finished-with-exit-code-1073740940-0xc0000374-python
> From here I see
> https://social.technet.microsoft.com/Forums/windows/en-US/578396fd-29c0-4dd3-b002-5e2e8df1b398/exception-code-0xc0000374?forum=w7itprogeneral
> --> exception code 0xc0000374 indicates a heap corruption
> which is discussed here:
> https://social.microsoft.com/Forums/Azure/en-US/2b2d5d37-ff69-481e-aab2-5b29e2801941/wpf-process-crashing-with-error-code1073740940?forum=Offtopic
> https://stackoverflow.com/questions/1010106/how-to-debug-heap-corruption-errors
> Question to you: could you provide a small example with dataset?
> Regards,
> Markus
> Markus Neteler, PhD
> http://www.mundialis.de - free data with free software
> http://grass.osgeo.org
> http://courses.neteler.org/blog
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20181011/0cf61b3d/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20181011/0cf61b3d/attachment-0001.obj>
More information about the grass-web
