[GRASS-web] GRASS error -- no 3D Raster visualization
Anna Petrášová
kratochanna at gmail.com
Fri Aug 2 12:28:00 PDT 2019
please subscribe to the grass-user mailing list, your question would be
more appropriate there.
You can display volumes either using slices or isosurfaces, but you need to
add them first to see anything:
see eg.
https://youtu.be/CmK-fEyf2SY
On Fri, Aug 2, 2019 at 1:32 PM Lindsi Seegmiller <lindsi at kth.se> wrote:
> Hi,
> I have been working on visualizing simple 3d Raster grids in GRASS. I
> have directly copied the examples from the grass website help for
> r3.in.ascii and r3.out.ascii, yet I cannot see on the display in grass.
> I have tested 2d grids with examplse from the grass website r.in.ascii and
> successfully see the grid.
> I have imported a sample 3d file that is not an asci and have been able to
> see that, so I imagine it’s something to do with the r3.in.ascii.
> Can you please check to see if you can see this simple 3D raster grid? I
> have tried both this with the version and order header as well as without
> using the default settings. Neither work. I have not attached it for fear
> the attachment might send my email to junk. But you can see it on the
> screenshot above or get it from the website:
> https://grass.osgeo.org/grass74/manuals/r3.out.ascii.html
> Thanks,
> Lindsi
> grass-web mailing list
> grass-web at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-web
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20190802/fbbd2352/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20190802/fbbd2352/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20190802/fbbd2352/attachment-0003.jpg>
More information about the grass-web
