[GRASS-web] How to install GRASS Add-Ons after migration from SVN to Github?
Helmut Kudrnovsky hellik at web.de
Mon Jul 15 23:47:50 PDT 2019
Brittney Bourdages wrote
> Hello,
> I'm new to GRASS and in the past I have had no issue installing add-ons.
> Recently I tried to install "r.stream.order" and got the following error:
> g.extension extension="r.stream.order"
> Extension r.stream.order not found
> I have tried installing the add-on both through the shell and the GRASS
> GUI. I have also downloaded the zipped file and tried to use the url
> option
> with the g.extension tool to install the add-on, but I get the same error.
> Although, this may have failed because the url option is supported only on
> Linux or Mac.
> g.extension extension="r.stream.order" url=C:\Downloads\r.stream.order.zip
> I read that the add-ons are installed by default from the GRASS SVN
> repository, which has recently been migrated to github and the svn repo
> now
> only has read-only access.
> Has anyone run into this error recently? If write only access to the SVN
> is
> causing the error, does anyone have any recommendations for how to resolve
> this issue and install the add-on?
> Note: I have GRASS 7.6 installed on a Windows computer.
> Thank you for any help you can offer!
the addon system for winGRASS isn't yet adapted after the switch to git;
it's still a work in progress.
downloading and installing the zip-file doesn't work in winGRASS as there is
some compilation and packaging preparation needed that the addon works.
forwarding this message to the GRASS dev list.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Website-f4053612.html
More information about the grass-web mailing list
