[GRASS-web] Installing r.green is not possible
Annemarie Pfeiffer Annemarie.Pfeiffer at umwelt.uni-giessen.de
Wed Nov 13 05:24:52 PST 2019
Dear Markus,
Thank you for your reply. I use the GRASS GIS version 7.8.1 with
Microsoft Windows. I have now installed Linux as a virtual machine and
will try again today to install and use the tools. With me similar
error codes occur as with you. The fact that the error codes are
different could also be due to the different operating systems
(Windows / Linux). The applications can be successfully installed, but
their execution fails. If it helps, I can also gladly send you my
error codes with Windows.
Best regards,
Annemarie
Zitat von Markus Neteler <neteler at osgeo.org>:
> Dear Annemarie,
> Which GRASS GIS version do you use, and on which operating system?
> I have tried to install it myself, on a Linux system:
> GRASS 7.8.2dev (nc_spm_08):~ > g.extension r.green
> Fetching <r.green> from GRASS GIS Addons repository (be patient)...
> Compiling...
> Traceback (most recent call last):
>   File
> "/home/mneteler/tmp/grass7-mneteler-20201/tmpfggv6w9y/r.green/scripts/r.green.hydro.structure",
> line 139, in <module>
>     from libgreen.checkparameter import check_required_columns,
> exception2error
> ModuleNotFoundError: No module named 'libgreen'
> make[2]: ***
> [/home/mneteler/software/grass78_git/dist.x86_64-pc-linux-gnu/include/Make/Html.make:14:
> r.green.hydro.structure.tmp.html] Error 1
> /home/mneteler/tmp/grass7-mneteler-20201/tmpfggv6w9y/r.green/scripts/r.green.install:35:
> DeprecationWarning: the imp module is deprecated in favour of
> importlib; see the module's documentation for alternative uses
>   import imp
> Installing...
> /usr/bin/install: cannot stat
> '/home/mneteler/tmp/grass7-mneteler-20201/tmpfggv6w9y/r.green/docs/html/r.green.hydro.structure.html':
> No such file or directory
> make[2]: ***
> [/home/mneteler/software/grass78_git/dist.x86_64-pc-linux-gnu/include/Make/Script.make:36:
> install] Error 1
> Updating addons metadata file...
> Updating private addons metadata file...
> WARNING: No addons metadata available. Addons metadata file not updated.
> Installation of <r.green> successfully finished
> GRASS 7.8.2dev (nc_spm_08):~ > r.green.
> r.green.biomassfor.co2          r.green.biomassfor.recommended
> r.green.gshp.theoretical        r.green.hydro.financial
> r.green.hydro.technical
> r.green.biomassfor.financial    r.green.biomassfor.technical
> r.green.hydro.closest           r.green.hydro.optimal
> r.green.hydro.theoretical
> r.green.biomassfor.impact       r.green.biomassfor.theoretical
> r.green.hydro.delplants         r.green.hydro.planning
> r.green.install
> r.green.biomassfor.legal        r.green.gshp.technical
> r.green.hydro.discharge         r.green.hydro.structure
> Some issue seems to be there with "libgreen".
> Do you see the same error?
> Best regards,
> Markus
> On Wed, Nov 6, 2019 at 11:38 AM Annemarie Pfeiffer
> <Annemarie.Pfeiffer at umwelt.uni-giessen.de> wrote:
>> Dear Sir or Madam,
>> as part of my master's thesis I would like to use the tool
>> r.green.hydro with all its functions. After I've completed all the
>> steps of your detailed online installation guide, Grass-Gis will
>> create a field called "Energy." The functions of this field are grayed
>> out and can not be executed. After entering the r.green.install -x
>> command, you also receive the message that the python libraries
>> numexpr and scipy are not available. After I installed these manually,
>> the message did not occur anymore, but the functions in "Energy" were
>> also not executable and still written in gray.
>> Additionally, when you load Grass-GIS into the black console, you see
>> the following message:
>> Details: Can not find the executable r.green.hydro ....
>> r.green.hydro ...: Unable to fetch interface description for command
>> 'r.green.hydro ....' "
>> Since I would benefit greatly from the use of the tool for my
>> explorations, I would be very grateful if you could help me with my
>> problem.
>> With best regards
>> Annemarie Pfeiffer
>> Mit freundlichen Grüßen
>> Annemarie Pfeiffer
>> grass-web mailing list
>> grass-web at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-web
> Markus Neteler, PhD
> https://www.mundialis.de - free data with free software
> https://grass.osgeo.org
> https://courses.neteler.org/blog
Annemarie Pfeiffer
More information about the grass-web mailing list
