[winGRASS] m.proj fails in wingrass?
Mike Thomas
mthomas at gil.com.au
Mon Jun 11 01:10:29 EDT 2001
Hi Bob.
> Initializing OUTPUT projection ELLIPSOID:WARNING: Lines 34, 37, 38, 40,
42, 4 (truncated)
> 59, 64, 66, 72,
> 78, 80, 82, 84, 86, 88, 90, 96, 98, 103, 105, 107, 109, 111, 113,
> 115, 120, 122, 126, 130, 134, 138 of ellipsoid table file
> </usr/local/grass5/etc/ellipse.table> are invalid
This is almost certainly a text/binary mode file read problem. I have had
simlar problems with other parts of Grass under CYgwin.
To work around this try setting your project up under a directory which is
mounted in binary mode. Likewise install Grass on a binary mounted
directory.
Use paths like "/cygdrive/e/.....", rather than //e/ when changing
directory, as Cygwin has problems with the double slash prefix.
Cheers
Mike Thomas.
More information about the grass-windows
