[winGRASS] m.proj fails in wingrass?
    Andreas Lange
    Andreas.Lange at Rhein-Main.de
    Fri Jun  8 11:03:20 EDT 2001
Hi Bob,
could you please tell me the following:
- which cygwin version do you use? (release of cygwin dll)
- which operating system (Windows NT 4.0, 2000 Prof. etc.) you use.
I expirienced many problems with the lates cygwin dll reading and
writing data, so this could explain the problem reading the
ellipse.table and printing the utm values (NaN errors). I have no clue
what this is (library broken in cygwin?) and have no time to fix.
But this seems no GRASS related problem.
HTH,
Andreas
Bob Sandefur wrote:
> Hi
>  I am using wingrass from grass5.0.0pre1_i686-pc-cygwin_bin.tar.gz and  get a m.proj failure as shown at bottom of this email. However the linux version works fine.
> Can anyone else get m.proj to fail?
> thanx
> Robert L Sandefur (Bob)
> Principal Geostatistician
> Pincock Allen & Holt (A Hart Crowser Company)
>  International Minerals Consultants
>  274 Union Suite 200
>  Lakewood CO 80228
>  USA
>  303 914-4467  v
>  303 987-8907 f
>                    Coordinate Conversions
>     1- Conversion       2- Input/Output Selection
>     3- Quit
>     Enter your selection [3] : 1
> Initializing INPUT PROJECTION:
> Please specify projection name
> Enter 'list' for the list of available projections
> Hit RETURN to cancel request
> >ll
> Initializing OUTPUT PROJECTION:
> >utm
> Initializing OUTPUT projection ELLIPSOID:WARNING: Lines 34, 37, 38, 40, 42, 4 (truncated)
> 59, 64, 66, 72,
>          78, 80, 82, 84, 86, 88, 90, 96, 98, 103, 105, 107, 109, 111, 113,
>          115, 120, 122, 126, 130, 134, 138 of ellipsoid table file
>          </usr/local/grass5/etc/ellipse.table> are invalid
> Please specify ellipsoid name
> Enter 'list' for the list of available ellipsoids
> >clark66
>     Enter OUTPUT Projection Zone [zone] : 13
> OUTPUT Projection: Would you like to use South Hemisphere (y/[n]) ?
> Enter plural for OUTPUT units [meters]:
> Parameters used in OUTPUT projection:
>          +proj=utm +a=63782064.0000000000 +es=0.7500000000 +zone=13 +unfact=1
>                  Lat/Long->Coord Conversion
>     Enter Latitude [dd:mm:ss{N|S}]: 39:00:00N
>     Enter Longitude [ddd:mm:ss{E|W}]: 105:00:00W
>     Lat/Lon -> Universe Transverse Mercator  Conversion:
>         Longitude       Latitude        X (meters)      Y (meters)
>         105:01W         39:01N                 NaN             NaN
> winGRASS mailing list
> winGRASS at www.geog.uni-hannover.de
> http://www.geog.uni-hannover.de/mailman/listinfo/wingrass
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
More information about the grass-windows
