[winGRASS] cannot find Init.sh
ziyadin cakirz at itu.edu.tr
Thu May 31 03:04:54 EDT 2001
Hi Markus and Malcome,
Thank you for your recomendations. At first, I
compiled source code of Baylor last month.
The problem  was that most of the modules (270 command)
were not compiled.
I tried to do it manually using gmake5 but no luck.
That is why I tried to install a precompiled version.
This time I got the source code from Hannover (grass5.0.0pre1)
but, it is the same problem. Forexample none of the raster or mapdev
was install. The followings are a few examples from the error.log file.
Module source code not installed: src/raster/r.what (ignored)
Module source code not installed: src/raster/r.surf.idw2 (ignored)
Module source code not installed: src/mapdev/v.surf.rst (ignored)
I would be appreciate any suggestion
Cheers,
Ziyadin
Malcolm Blue wrote:
> Hi,
> You should download the more recent binaries.  Grass5 pre-release is
> available now (after beta 12), or will be available soon for most
> supported platforms.  Beta9 was replaced by beta10 after 1 day because
> of "severe installation" bugs.  If the new solaris binaries are not
> available now, they should be very soon.  Since there have been a lot of
> improvements since beta9, it will be worth a short wait.
> If you can't wait, it is usually straight forward to compile yourself.
> Instructions are available at the grass web site and in the source
> download.
> Malcolm
> ziyadin wrote:
> > Dear grass user,
> > I have intalled grass5.0beta9_solaris binaries.
> > When  i give the command grass5 i get this
> > error mesage
> > /usr/local/bin/grass5: /usr/local/grass5/etc/Init.sh: not found
> > If i fallow the default setup grass is stored in
> > /usr/local/grass5/grass5.0beta9_solaris/grass5(/dev etc...)
> > I came around this problem and now it is in
> > usr/local/grass5(/dev etc...)
> > I could not find this script. Am I supposed to create it myself?
> > I would be glad if I could get any help.
> > Cheers,
> > Ziyadin
> > ____________________________________________________________
> > Ziyadin CAKIR                          Tel:++90 +212 2856320
> > Istanbul Technical University          Fax:++90 +212 2856210
> > Mining Faculty, Geology Department    Mail:cakirz at itu.edu.tr
> > Maslak/Istanbul/TURKEY
> > winGRASS mailing list
> > winGRASS at www.geog.uni-hannover.de
> > http://www.geog.uni-hannover.de/mailman/listinfo/wingrass
More information about the grass-windows mailing list
