[winGRASS] cannot find Init.sh
Malcolm Blue mblue at nb.sympatico.ca
Wed May 30 19:45:53 EDT 2001
Markus,
I had a quick look at the baylor site, and beta9 is still there in the
solaris binary distribution directory.  Can you inform them (if they
don't monitor this list)?
Malcolm
Markus Neteler wrote:
> On Wed, May 30, 2001 at 05:11:34PM +0300, ziyadin wrote:
> > Dear grass user,
> > I have intalled grass5.0beta9_solaris binaries.
> > When  i give the command grass5 i get this
> > error mesage
> > /usr/local/bin/grass5: /usr/local/grass5/etc/Init.sh: not found
> > If i fallow the default setup grass is stored in
> > /usr/local/grass5/grass5.0beta9_solaris/grass5(/dev etc...)
> > I came around this problem and now it is in
> > usr/local/grass5(/dev etc...)
> > I could not find this script. Am I supposed to create it myself?
> > I would be glad if I could get any help.
> > Cheers,
> Hi Ziyadin,
> sorry for your inconvenience, but the grass5.0beta9_solaris binaries
> shouldn't be used due to such errors. Where did you get this
> package (it should have been removed everywhere!)?
> Very soon a new solaris release should be available. In case you
> know how to compile, I recommend to get GRASS 5.0.0pre1 source code
> and compile locally unless the Solaris binaries are available.
> Kind regards
>  Markus Neteler
> winGRASS mailing list
> winGRASS at www.geog.uni-hannover.de
> http://www.geog.uni-hannover.de/mailman/listinfo/wingrass
More information about the grass-windows mailing list
