[winGRASS] libG11
    Malcolm Blue
    mblue at nb.sympatico.ca
    Tue Oct  2 07:00:00 EDT 2001
Markus,
I've been meaning to update the README with a note on how to use it.
In directory windows/libW11 do:
make clean        (if necessary)
make
make install
That will copy libG11.dll to /usr/local/bin.  This should already be in your
path.
Change XLIB and XCFLAGS to point to the libW11/lib and the libW11 directory.
Add the -D__W98__ to COMPILE_FLAGS for Win98 (I use it anyway).
Then recompile the XDRIVER to use the new lib:  Clean out OBJ* and run
gmake5 within the XDRIVER24 directory.
I'll check your new docs as well.
Good luck,
Malcolm
> -----Original Message-----
> From: Markus Neteler [mailto:neteler at itc.it]
> Sent: Tuesday, October 02, 2001 6:52 AM
> To: Mike Thomas
> Cc: Malcolm Blue; Roberto Flor; Glynn Clements; wingrass at grass.itc.it
> Subject: Re: [winGRASS] libG11
> Hi all,
> today I have started to try the new generic windows display
> driver. For my convenience I wrote a short INSTALL-WIN
> file from Mike's hints, in CVS at:
> src/display/devices/windows/INSTALL-WIN
> I also updated the page:
> http://grass.itc.tt/grass5/binary/windows_cygnus/cygwin_grass50com
pile.html
(in CVS in doscuments/cygwin_grass50compile.html)
However, I got stuck...  CVS is working (so that I got the latest code),
GRASS is compiled so far within the Cygwin, but how to compile the
libG11.dll and the Xdriver properly?
I would be glad if someone could either tell me and/or update the
new INSTALL-WIN file.
Thanks in advance,
 Markus
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.281 / Virus Database: 149 - Release Date: 9/18/2001
Outgoing mail is certified Virus Free.
More information about the grass-windows
