[winGRASS] libG11
    Markus Neteler
    neteler at itc.it
    Tue Oct  2 08:15:19 EDT 2001
Hi Andreas,
On Tue, Oct 02, 2001 at 01:35:38PM +0200, Andreas Lange wrote:
> Hi Markus, Hi all,
> Markus Neteler wrote:
> > Hi all,
> > today I have started to try the new generic windows display
> > driver. For my convenience I wrote a short INSTALL-WIN
> > file from Mike's hints, in CVS at:
> > src/display/devices/windows/INSTALL-WIN
> > I also updated the page:
> > http://grass.itc.tt/grass5/binary/windows_cygnus/cygwin_grass50compile.html
> > (in CVS in doscuments/cygwin_grass50compile.html)
> This page is way outdated. I focus on makeing GRASS compile somoothly on
> cygwin, so i have no time to update. It is also my impression that we
> should distribute winGRASS as a binary, so there is no need to update
> the compiling instruction.
well, I think the compile process must be documented unless it is identical
to the common GRASS compilation. I really didn't mind to update (and sorry,
the web was pointing to an old version, fixed). So it should be a sort
of current now (but doesn't reflect latest driver developments yet, see
local file for that or my other mail).
> > However, I got stuck...  CVS is working (so that I got the latest code),
> > GRASS is compiled so far within the Cygwin, but how to compile the
> > libG11.dll and the Xdriver properly?
> > I would be glad if someone could either tell me and/or update the
> > new INSTALL-WIN file.
> Though i had no time to test, i think you need to follow the
> instructions in the INSTALL-WIN file and additionally compile the lib
> from src/display/devices/windows/libW11 with the  makefile from there.
Yes, I have been writing this file today :-)
> This is all the same than on linux ;-) except that a dll is built
> instead of an archive or a so. Do a 'make' and copy the dll from the lib
> dir over to /usr/local/lib or similar.
Thanks! BTW: Compilation is done and the new native driver running.
Great work!
Best regards
 Markus Neteler
More information about the grass-windows
