[GRASS5] RE: [winGRASS] libG11
Malcolm Blue mblue at nb.sympatico.ca
Wed Oct 3 00:53:37 EDT 2001
Hi all,
For those who are testing the native windows XDRIVER, there are some strange
behaviors which still need to be fixed.  Some suggestions if you run into
trouble:
d.zoom seems to act strangely and zooms in too far sometimes (I think we
need to correct Pixmap to screen conversion, I just haven't had a chance to
look):  To fix improper zooms, either use g.region or fix with an X Window
version.  You can also usually zoom out several times to fix it.  For now
don't zoom in to too a small region.
Sometimes the screen doesn't refresh when expected.  Resizing the screen
'usually' refreshes the screen, but for me only stretching horizontally, not
vertically.  So to do a redraw grab the side of the window and resize it a
bit.  (I have partial fix for this, but will need to do more testing and fix
the other RESIZE/REPAINT events before submitting)
There are other strange behaviors,  but right now I don't have my linux
version to compare to so I'm not sure what is the correct behavior.  Please
report problems as you find them to this list.
Be sure that you are using the latest version, since there were some fatal
errors from the original version.
Malcolm
> -----Original Message-----
> From: grass5-admin at grass.itc.it [mailto:grass5-admin at grass.itc.it]On
> Behalf Of Malcolm Blue
> Sent: Tuesday, October 02, 2001 9:58 PM
> To: Markus Neteler; Mike Thomas
> Cc: Roberto Flor; Glynn Clements; wingrass at grass.itc.it; grass5
> developers list
> Subject: [GRASS5] RE: [winGRASS] libG11
> For everyone who is testing out the new native windows code:
> I've just loaded to CVS a bug fix to the libG11 code that fixes
> the windows
> memory leak in interactive calls.  Please update your copy of
> libW11/w32/xlib.c and remake the library to get more enjoyment of
> the code.
> This is (WAS) a fatal bug as you may have noted from some of the winGRASS
> list postings (from the original code - not any of Mike or my fixes :) ).
> Keep on testing.
> Enjoy,
> Malcolm
> PS  I have cleaned up the event handling as per Glynn's advice,
> but it still
> needs some work.
> > From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]On
> > Behalf Of Markus Neteler
> > Sent: Tuesday, October 02, 2001 9:12 AM
> > To: Mike Thomas
> > Cc: Malcolm Blue; Roberto Flor; Glynn Clements; wingrass at grass.itc.it;
> > grass5 developers list
> > Subject: Re: [winGRASS] libG11
> > Hi all
> > GREAT NEWS.... the native windows GRASS display driver is working!!
> > Many, many thanks to all contributors for this major step. I am aware
> > that the new windriver is not finished, but d.rast and d.vect
> are working
> > so far (I'll test more now).
> > Here my latest build instruction (note: I have added a convenient
> > Gmakefile in src/disply/devices/windows/ and fixed some .h files
> > (dos2unix) and the Makefiles for libG11, find in CVS).
> > If other want to try, you may proceed as follows:
> > (file is src/display/devices/windows/INSTALL-WIN, please improve if
> > required)
> > $Id: INSTALL-WIN,v 1.1.2.3 2001/10/02 12:12:13 markus Exp $
> > From: "Mike Thomas" <miketh at brisbane.paradigmgeo.com>
> > Re: [winGRASS] Re: generic Windows GRASS driver
> > Slightly updated by Markus Neteler
> > 1. setting up cygwin
> > See instructions:
> > http://grass.ttc.it/grass5/binary/windows_cygnus/cygwin_grass50com
> > pile.html
> > The X stuff and the TCL/TK stuff are not relevant if you are
> doing a Win32
> > native driver - so save yourself some time there.
> > My configure script:
> > #! /bin/bash -ef
> > CFLAGS=-g ./configure --enable-postgres=no
> > --with-tcltk-libs=/usr/local/lib
> > --with-tcltk-includes=/usr/local/include --with-gdal
> > --with-postgres-includes=/usr/include/postgresql
> > --with-postgres-libs=/lib >& configure.log
> > Then build GRASS:
> > make
> > > 3. compile libG11 (native windows display driver .dll)
> > $ `pwd`/bin.i686-pc-cygwin/gmake5  `pwd`/src/display/devices/windows
> > > 4. recompile Xdriver
> > These changes in "src/CMD/head/head.i686-pc-cygwin" required:
> > COMPILE_FLAGS       = -O -D__W98__
> > LDFLAGS             =
> > XCFLAGS             =
> > -I/grass5.0.0pre2/grass/src/display/devices/windows/libW11
> > XLIBPATH            =
> > -L/grass5.0.0pre2/grass/src/display/devices/windows/libW11/lib
> > XLIB                = -lX11
> > XTLIB               =
> > XMLIB               =
> > XEXTRALIBS          =
> > XTLIBPATH           =
> > XMLIBPATH           =
> > PART 3 - Rebuilding "display/devices", "d.mon" etc
> > 3.a XDriver:
> >  Delete all the "OBJ.i686-pc-cygwin/*"  files
> >  cd src/display/devices
> >  find . -type d -name 'OBJ.*' -exec rm -rf {} \;
> > 3.b d.mon
> > Likewise d.mon, although probably unnecessary, although the
> > __W98__ changes
> > affect it.
> >  cd src/display/d.mon
> > Start Grass, and type "d.mon x0" - you should get a bunch of debugging
> > output and a display. Happy testing...
> > GREAT WORK!!!
> > Thanks again.... Congrats!
> >  Markus Neteler
> > winGRASS mailing list
> > winGRASS at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/wingrass
> > Incoming mail is certified Virus Free.
> > Checked by AVG anti-virus system (http://www.grisoft.com).
> > Version: 6.0.281 / Virus Database: 149 - Release Date: 9/18/2001
> Outgoing mail is certified Virus Free.
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
More information about the grass-windows mailing list
