[winGRASS] libG11
Malcolm Blue
mblue at nb.sympatico.ca
Wed Oct 3 15:28:00 EDT 2001
Markus, Roberto,
There were only a couple of places in the Cygwin tcl/tk source where they
needed fixing to avoid the path issue. I didn't spend a lot of time trying
to compile as just a cygwin/windows compatible library, but I don't think it
was far from successful compile. I will have a look to see if I saved that
work, to perhaps save you some time.
Malcolm
> -----Original Message-----
> From: Markus Neteler [mailto:neteler at itc.it]
> Sent: Wednesday, October 03, 2001 1:00 PM
> To: Malcolm Blue
> Cc: Glynn Clements; Mike Thomas; Roberto Flor; wingrass at grass.itc.it
> Subject: Re: [winGRASS] libG11
> Hi all,
> Roberto flor and me did some tests with NVIZ. Following situation
> we have:
> - tcl/tk 8.0 is already present in cygwin (latest)
> [don't install the xtcltk package from grass-server!]
> this version contains some path problems, see below.
> - we did some NVIZ hacking to include missing header files,
> fixed two general include problems and a missing definition
> in Xlib.h (libG11). NVIZ now compiles! we had to remove from
> Gmakefile.in
> the references to -lXmu -lXext, they should arrive through configure on
> $(XEXTRALIBS) for non windows platforms. We added some files
> from tlctk
> sources on windows and flagged some part of togl.c code for X11 only
> We have fixed the togl.c and the missing files in CVS already.
> Glynn, may I ask you to look into the configure problem related
> to -lXmu -lXext?
> Again, when manually changing the Gnakefile, NVIZ now compiles without
> libG11. It pops up a window for a few seconds (see other
> tcl/tk problems
> below).
> - other change for configure:
> under win32/cygwin we need in head
> OPEGLLIB = -lopengl32
> OPENGLULIB = -lgdi32 -lglu32
> It could be useful to remove also -lX11 from head, putting it back
> just on the Gmakefile for Xdriver, the only point where we need X11
> on win32 compilation.
> - Problem: the tcl/tk does not support cygwin-paths properly,
> see CYGWIN-FAQ here:
> http://www.cygwin.com/faq/faq_4.html#SEC65
> This means that neither tcltkgrass nor NVIZ will work since
> the code is spreaded within several directories.
> A solution is to use the TCL_LIBRARY variable, but we are unable
> to define multiple paths here, since you have to define the
> driver number ("c:") as well, but ":" is also the path separator...
> Tomorrow (?) we'll try to rebuild the tcl/tk.
> - tcltkgrass: if the multiple path problem would be fixed (CYGWIN-FAQ),
> it may run ...
> So far for today,
> cheers
> Roberto and Markus
> Incoming mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.281 / Virus Database: 149 - Release Date: 9/18/2001
Outgoing mail is certified Virus Free.
More information about the grass-windows
