[winGRASS] libG11
Markus Neteler
neteler at itc.it
Wed Oct 3 12:00:10 EDT 2001
Hi all,
Roberto flor and me did some tests with NVIZ. Following situation
we have:
- tcl/tk 8.0 is already present in cygwin (latest)
[don't install the xtcltk package from grass-server!]
this version contains some path problems, see below.
- we did some NVIZ hacking to include missing header files,
fixed two general include problems and a missing definition
in Xlib.h (libG11). NVIZ now compiles! we had to remove from Gmakefile.in
the references to -lXmu -lXext, they should arrive through configure on
$(XEXTRALIBS) for non windows platforms. We added some files from tlctk
sources on windows and flagged some part of togl.c code for X11 only
We have fixed the togl.c and the missing files in CVS already.
Glynn, may I ask you to look into the configure problem related
to -lXmu -lXext?
Again, when manually changing the Gnakefile, NVIZ now compiles without
libG11. It pops up a window for a few seconds (see other tcl/tk problems
below).
- other change for configure:
under win32/cygwin we need in head
OPEGLLIB = -lopengl32
OPENGLULIB = -lgdi32 -lglu32
It could be useful to remove also -lX11 from head, putting it back
just on the Gmakefile for Xdriver, the only point where we need X11
on win32 compilation.
- Problem: the tcl/tk does not support cygwin-paths properly,
see CYGWIN-FAQ here:
http://www.cygwin.com/faq/faq_4.html#SEC65
This means that neither tcltkgrass nor NVIZ will work since
the code is spreaded within several directories.
A solution is to use the TCL_LIBRARY variable, but we are unable
to define multiple paths here, since you have to define the
driver number ("c:") as well, but ":" is also the path separator...
Tomorrow (?) we'll try to rebuild the tcl/tk.
- tcltkgrass: if the multiple path problem would be fixed (CYGWIN-FAQ),
it may run ...
So far for today,
cheers
Roberto and Markus
More information about the grass-windows
