[winGRASS] libG11
Glynn Clements
glynn.clements at virgin.net
Wed Oct 3 20:10:12 EDT 2001
Markus Neteler wrote:
> Glynn, may I ask you to look into the configure problem related
> to -lXmu -lXext?
Those libraries don't appear in head.i686-pc-linux-gnu. They are added
by src.contrib/GMSL/NVIZ2.2/src/Gmakefile.in.
The libGL from XFree86 requires libXext, and togl.c requires libXmu
for XmuLookupStandardColormap().
IOW, this isn't a configure issue; it's an NVIZ issue.
> Again, when manually changing the Gnakefile, NVIZ now compiles without
> libG11. It pops up a window for a few seconds (see other tcl/tk problems
> below).
> - other change for configure:
> under win32/cygwin we need in head
> OPEGLLIB = -lopengl32
> OPENGLULIB = -lgdi32 -lglu32
> It could be useful to remove also -lX11 from head, putting it back
> just on the Gmakefile for Xdriver, the only point where we need X11
> on win32 compilation.
"-lX11" only occurs in the definition of XLIB. This definitely needs
to stay.
Also, as well as XDRIVER and NVIZ, d.scale uses libX11 for "d.scale
-i". As I've mentioned before, this is an ugly hack; there is no way
that "d.scale -i" can be implemented correctly without extending the
display driver protocol.
I would very strongly advise against trying to shoehorn the existing
build system into supporting Windows (as opposed to Cygwin).
Apart from:
a) the work to build XDRIVER with libG11 (which should be usable
soon), and
b) using tcltkgrass with Windows' Tcl/Tk (AFAICT, tcltkgrass should be
a "pure" Tcl/Tk application).
the rest (i.e. NVIZ) should wait for 5.1. Otherwise, you risk:
a) making a complete mess of the configure/build system, and
b) breaking support for Cygwin with an X server, which should be a
usable platform.
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows
