[winGRASS] more in Wingrass?
Andreas Lange
Andreas.Lange at Rhein-Main.de
Fri Sep 7 13:13:40 EDT 2001
Hi Bob,
Bob Sandefur wrote:
> Hi-
> Question:
> Does more exist in cygwin (or grass5) and if so where is it?
> Background:
> After Boss Billy Gates dog XP (prerelease build 2505) ate one of my hard drives (maybe it wasn't XP but the directory got trashed when I was running XP), I went back to windows 2000 with a clean install, installed cygwin from net and installed grass5, which based on limited testing works okay. However, in console mode m.proj failed to list projection properly because more was not found. To fix this in /bin I cp'ed less.exe to more.exe and m.proj list works fine.
> thanx
> bob
There is no more in cygwin by default. I once implemented a check in the
install script to create automatically the link if more is missing, but
for unknown reasons this does not work. You may copy less.exe to
more.exe or create a softlink, as you like. Copying may be better, as
the soft links are not visible outside the cygwin environment.
I would be happy if you could sometimes scribble down a list of
modules/programs you did run and find working. I maintain a list of
modules i tested on cygwin. We need more user feedback to verify that
the cygwin port works and which parts are buggy/not working.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
More information about the grass-windows
