[winGRASS] bug: v.trim missing
Matt & Kim patawi at polarcom.com
Thu Apr 4 01:21:27 EST 2002
>> Is this [v.trim] command deprecated or broken? If deprecated what is its
>> replacement? If broken is it being worked on?
>broken, yes... Could you please try v.rmdup and tell us if it provides
>the desired functionality and works o.k.?
v.rmdup does not delete dangling lines, though I see v.spag does so perhaps
the two in combination. After a more careful reading of the man pages, none
of these progams does (completely) what I'm wanting; which is:
- extend endpoints of lines across gaps
- remove dangles
- remove redundant nodes
- remove "jaggies"; change a "connect the dots" type jagged line to a
smooth spline-like line.
The source data is vectors which have been created with r.line
Another question: when a program like v.rmdup asks for a threshold value,
what units are being used? meters? feet? degrees? etc.
cheers,
-matt
More information about the grass-windows mailing list
