[winGRASS] compiling native windows driver
Glynn Clements
glynn.clements at virgin.net
Tue Feb 26 16:50:52 EST 2002
Andreas Lange wrote:
> But it does not work. I can compile the sources with the --enable-w11
> flag.
> The error log notices an error in src/display/devices/XDRIVER
> (ignored).
What error message does the compiler/linker generate?
> But if i run "d.mon start=x0" i get a complaint that libX11.dll is not
> found.
> I have found:
> src/display/devices/windows/libW11/lib/
> libG11.dll
> libX11.a (no .dll!)
> And i have some "libW11.dll" around, don't know from where this comes.
> My libX11.dll is in /usr/X11R6/bin, so this is from the X11R6 from
> cygwin.
> If i add /usr/X11R6/bin to the path, i get the error that the socket can
> not be connected to.
> Do i have to deinstall X11R6?
You may need to use the "--without-x" switch.
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows
