[winGRASS] Can't start TCLTKGRASS in winGrass with generic version
Markus Neteler
neteler at itc.it
Tue Mar 26 10:52:19 EST 2002
On Wed, Mar 27, 2002 at 12:40:45AM +0900, Hisaji ONO wrote:
> Hello.
> Today I found winGrass with generic version xand installed it in my PC.
> I've been very impressed with Easy installing.
that's good news for us - thanks.
> However, TclTkGRASS couldn't run in this winGrass. winGrass said "Can't
> open tcltkgrass: No such file or directory", but TclTkGRASS does exist.
> Could you tell me any solution.
It depends: since yesterday two winGRASS versions are online at
http://grass.itc.it/grass5/binary/windows_cygnus/
o winGRASS with Xserver requirement: wingrass_xserver/
o winGRASS without Xserver requirement: wingrass_generic/ (eventually more
limited in functionality)
If you are refering to winGRASS with Xserver requirement, you have to
install the package xtcltk8.0.5-CYGWIN....
If you are refering to winGRASS without Xserver requirement, the
"tcltkgrass" is not present because there are limitations in the underlying
tcl/tk libraries. You may try to install "ActiveTcl" to overcome the
problem:
http://aspn.activestate.com/ASPN/Downloads/ActiveTcl/
eventually then it will be working. Please inform us about your results
when trying ActiveTcl.
Best regards
Markus Neteler
More information about the grass-windows
