[winGRASS] Can't start  TCLTKGRASS in winGrass with generic version
    Glynn Clements
    glynn.clements at virgin.net
    Wed Mar 27 05:21:11 EST 2002
Andreas Lange wrote:
> - my "xtcltk" distribution works quite well with the StarNet XWin
> Server, its a bit slow. With the XFree86 for cygwin it is unbearable
> slow and there are some problems with the Server (no localized keyboards
> by default, 3 buttons mice not emulated with 2 buttons by default etc.).
I found that NVIZ almost works with the "xtcltk" package. The only
problem is the same one as MacOS: it can't find the "library"
directories.
Application initialization failed: Can't find a usable init.tcl in the
following directories:
    /usr/src/tcltk-patches/build/usr/local/lib/tcl8.0
    /home/Glynn/grass-build/dist.i686-pc-cygwin/etc/lib/tcl8.0
    /home/Glynn/grass-build/dist.i686-pc-cygwin/lib/tcl8.0
    /home/Glynn/grass-build/dist.i686-pc-cygwin/etc/library
    /home/Glynn/grass-build/dist.i686-pc-cygwin/library
    /home/Glynn/grass-build/dist.i686-pc-cygwin/tcl8.0/library
    /home/Glynn/grass-build/tcl8.0/library
The executable is:
	/home/Glynn/grass-build/dist.i686-pc-cygwin/etc/nviz2.2/NVWISH2.2
If I create symlinks, it works.
I note that there is one path which isn't relative to the location of
the executable, but this appears to be relative to the build
directory. Is there some compilation option which would make it look
in /usr/local/lib?
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows
