[winGRASS] d.mon/fifo problems
Mike Thomas
miketh at brisbane.paradigmgeo.com
Tue Jan 7 23:19:14 EST 2003
Hi Haro.
> Apparently mknod and mkfifo commands do not
> work properly in cygwin (at least in my release) - I am getting message
> "Function is not implemented". Can you advise me how to start d.mon
> monitor now?
> NVIZ works fine, though rather slow. But for simple and quick
> visualization I would need d.mon as well.
Grass 5.0 does not use fifo's but rather uses sockets to communicate with
the monitor. Check that you are using the source available at:
http://grass.itc.it/wingrass.html
If this is what you have then you'll need to check your configure and make
logs to see what went wrong.
Alternatively try the binary builds available from the above site.
Cheers
Mike Thomas.
More information about the grass-windows
