[winGRASS] xwin ok but grass errors
    Royden Yates
    ryates at iziko.org.za
    Sat Aug 21 15:17:47 EDT 2004
I am running under XP home, with Cygwin (in C:\CYGWIN), Cygwin/X
server and Grass 5.7.0 (in
C:\cygwin\usr\local\grass5.7.0-i686-pc-cygwin-24_06_2004\) installed.
Installations appeared error free.
I start with
export DISPLAY=127.0.0.1:0
Xwin -multiwindows -clipboard &
grass57
I get the "Welcome to Grass       Version 5.7.0 screen
Hit RETURN to continue"
Xwin displays  "Starting GRASS...."
Then a problem emerges: a message box from 16bit MS-DOS Subsystem
The NTVDM CPU has encountered an illegal instruction
CS:0000 IP:0077 OP:f0 37 05 oc 02 Choose 'close' to terminate the
application"
If I click on 'ignore' a similar error box displays, this time
"CS:00cf IP:0308 OP:0f 04 00 00 00..." and so on with a different set
of numbers for each of 8 clicks on ignore.
Xwin is now returned to "Ryates at RYATES ~
with the following information above it:
"/home/ryates/<UNKNOWN>/<UNKNOWN>/.gislock: No such file or directory
ERROR: /usr/local/grass5.7.0-i686-pc-cygwin-24_06_2004/etc/lock:
Ryates is currently running GRASS in selected MAPSET. Concurrent use
not allowed."
Seems a configuration problem, but I believe I followed the
installation instructions. Yet that NTVDM CPU message seems
implicated.
Any help here?
Regards,
Royden
Royden Yates
Curator Researcher
Precolonial Archaeology Section
Social History Collections Division
Iziko: SA Museum
Tel: +27-21-4813882
Fax: +27-21-4813993
cell phone: 083 6906011
Name: Royden Yates.vcf
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-windows/attachments/20040821/4d7d8be6/RoydenYates.vcf
More information about the grass-windows
