[winGRASS] the " libgrass_gis.dll was not found !" problem
Huidae Cho
grass4u at gmail.com
Sat Dec 11 19:32:53 EST 2004
Could you explain how you got the error?
Which interface are you using?
1. commandline
2. d.m
3. tcltkgrass
Which command did you run and got the error?
1. ps.map
2. everything doesn't work
Please check your library dependency of whatever command you run:
cygcheck /usr/local/grass.../bin/ps.map
Then it should print libraries that it requires. Try this in and outside
grass.
Thanks.
Huidae Cho
On Sun, Dec 12, 2004 at 01:09:50AM +0200, Koukoulas Sotiris wrote:
> I downloaded the new binary version from http://geni.ath.cx/grass.html
> (thanks Huidae Cho) which had the .dll libraries in the lib folder. In
> fact it had a link to ***.5.7.cvs.dll files (e.g to
> libgrass_gis.5.7.cvs.dll)
> But again for some reason I had the same problem as before. It could not
> find the libgrass_gis.dll file. I decided to rename all the
> *.5.7.cvs.dll files to *.dll and it seems to work fine now.
> Huidae can you provide a better solution for this problem?
> Cheers,
> Sotiris
> -----Original Message-----
> From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]
> On Behalf Of Huidae Cho
> Sent: Saturday, December 11, 2004 10:12 AM
> To: wingrass at grass.itc.it
> Subject: [winGRASS] winGRASS 5.7 updated
> Hi,
> I know that some people are experiencing a problem with running grass
> that I'm distributing. Please make sure that you installed tcl/tk from
> my
> site. Cygwin version of tcl/tk doesn't work for grass.
> Find the latest version at http://geni.ath.cx/grass.html
> Thanks.
> Huidae Cho
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows
