[winGRASS] the " libgrass_gis.dll was not found !" problem
Koukoulas Sotiris
skouk at geo.aegean.gr
Sat Dec 11 20:24:01 EST 2004
It appeared as soon as I started the graphical interface of grass with
d.m (ps.map). I couldn't get to the main menu. I attach my first
message:
I have recently installed Grass 5.7 for Windows and I get an error
message as the Display Manager starts:
<ps.map - Unable to locate component
This application has failed to start because libgrass_gis.dll was not
found. Re-installing the application may fix this problem.>
In the xterm I get the following:
GRASS 5.7.0:~ > Error in startup script: child process exited abnormally
while executing
"exec ps.map -p" (procedure "DmPrint::init" line 14) invoked
from within
"DmPrint::init" (procedure "main" line 27) invoked from within
"main $argc $argv"
(file
"/usr/local/grass5.7.0-i686-pc-cygwin-24_06_2004/etc/dm/d.m.tcl" line
773)
-----Original Message-----
Sent: Sunday, December 12, 2004 2:33 AM
To: Koukoulas Sotiris
Cc: grass5 at grass.itc.it; wingrass at grass.itc.it; Patton, Eric;
info at thomas-reinfelder.de
Subject: Re: [winGRASS] the " libgrass_gis.dll was not found !" problem
Could you explain how you got the error?
Which interface are you using?
1. commandline
2. d.m
3. tcltkgrass
Which command did you run and got the error?
1. ps.map
2. everything doesn't work
Please check your library dependency of whatever command you run:
cygcheck /usr/local/grass.../bin/ps.map
Then it should print libraries that it requires. Try this in and outside
grass.
Thanks.
Huidae Cho
On Sun, Dec 12, 2004 at 01:09:50AM +0200, Koukoulas Sotiris wrote:
> I downloaded the new binary version from http://geni.ath.cx/grass.html
> (thanks Huidae Cho) which had the .dll libraries in the lib folder. In
> fact it had a link to ***.5.7.cvs.dll files (e.g to
> libgrass_gis.5.7.cvs.dll)
> But again for some reason I had the same problem as before. It could
not
> find the libgrass_gis.dll file. I decided to rename all the
> *.5.7.cvs.dll files to *.dll and it seems to work fine now.
> Huidae can you provide a better solution for this problem?
> Cheers,
> Sotiris
> From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]
> On Behalf Of Huidae Cho
> Sent: Saturday, December 11, 2004 10:12 AM
> To: wingrass at grass.itc.it
> Subject: [winGRASS] winGRASS 5.7 updated
> Hi,
> I know that some people are experiencing a problem with running grass
> that I'm distributing. Please make sure that you installed tcl/tk from
> my
> site. Cygwin version of tcl/tk doesn't work for grass.
> Find the latest version at http://geni.ath.cx/grass.html
> Thanks.
> Huidae Cho
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows
