Helmut Muenzing wrote: > My TCLTKGRASS 4.0(April 2004)interface does not have a Configuration Menu. > Though under File there is a Configure Menu which only lets you resize Menu Size > and select Menu Fonts. In 5.7, the Help buttons use the GRASS_HTML_BROWSER environment variable. -- Glynn Clements <glynn at gclements.plus.com>
