[winGRASS] Re: problem starting grass
Richard Greenwood
rich at greenwoodmap.com
Wed Oct 13 11:39:34 EDT 2004
I just googled "cygwinb19.dll" and found this suggestion:
"Just copy the current new cygwin1.dll to cygwinb19.dll
they are compatible, it should work."
Rich
Martin Perra wrote:
> I am using a new install of Cygwin, I installed everything EXCEPT tcl/tk
> libraries. I downloaded the proper ones from the grass5.7 directory, and
> installed using provided .sh file.
> I ran which -a wish, and came up with one in /usr/local/bin. Date is
> 3/28/2002, size is 1209kb file is wish8.3.exe
> I'll explain a little more background on the problem. At one point I had
> everything working properly. I then installed vis5d+ and that worked, but
> when I went back to grass, I got the error message i mentioned before.
> After trying a few things, I ended up deleteating Cygwin completly, and
> reinstalling, including grass (I have tried all versions 5, 5.3, 5.7) and
> get the same problem. I have tried doing full reinstalls afew times,
> including deleting all cygwin Windows registry entries with no luck.
> I don't recall if when I installed vis5d I had to get cygwinb19 from
> somwhere to make it work, It was awhile ago. I think I may have though,
> because it was requesting it, and I would have put it in c:\cygwin\bin.
> That may be what caused the problem, but like I said, I have since deleted
> all traces of it.
> I am wondering if it may be becuase of my home path? After install, it is
> set to a network share, which is my windows home directory. Could this be
> causing a problem? How might I fix it? I am fairly new to Unix-like
> sytems.
> I have just tried copying mysql.exe and the dll to /usr/local/bin but that
> didn't help.
> When installed cygwin, I got this message the first time I ran it.
> Your group is currently \"mkgroup\". This indicates that
> the /etc/group (and possibly /etc/passwd) files should be rebuilt.
> See the man pages for mkpasswd and mkgroup then, for example, run
> mkpasswd -l [-d] > /etc/passwd
> mkgroup -l [-d] > /etc/group
> Note that the -d switch is necessary for domain users.
> I'm not sure aht it means though.
> I hope that's enough information to work an answer out of!
> Thanks,
> Martin
> -----Original Message-----
> From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]On
> Behalf Of wingrass-request at grass.itc.it
> Sent: Sunday, October 10, 2004 4:01 AM
> To: wingrass at grass.itc.it
> Subject: winGRASS digest, Vol 1 #220 - 6 msgs
> Send winGRASS mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> http://grass.itc.it/mailman/listinfo/wingrass
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of winGRASS digest..."
> Today's Topics:
> 1. pg.dll not found in W2K Svp4 (Bayer.Juergen (FORST))
> 2. Re: pg.dll not found in W2K Svp4 (=?ISO-8859-1?Q?=C1d=E1m_Csaba?=)
> 3. include winGRASS with Cygwin distribution? (Gerrit P. Haase)
> 4. Re: problem starting grass (Richard Greenwood)
> 5. Re: problem starting grass (Gerrit P. Haase)
> 6. Re: problem starting grass (Gerrit P. Haase)
> --__--__--
> Message: 1
> From: "Bayer.Juergen (FORST)" <Juergen.Bayer at forst.bwl.de>
> Date: Sat, 9 Oct 2004 16:57:30 +0200
> Subject: [winGRASS] pg.dll not found in W2K Svp4
> This message is in MIME format. Since your mail reader does not understand
> this format, some or all of this message may not be legible.
> ------_=_NextPart_001_01C4AE10.4CD08420
> Content-Type: text/plain;
> charset="iso-8859-1"
> Content-Transfer-Encoding: quoted-printable
> Have just installed grass57 and the latest cygwin release from bineary
> installs.
> Get it started but after displaying the first maps or when opening most
> dialogs boxes, I get a PG.DLL is missing message from several tools =
> (e.g.
> ps.map). I think I had installed cygwin with almost all components.
> =20
> All on W2K, Svp4, German release
> =20
> Any idea what component is missing? If not: pg.dll should be located
> anywhere in the winnt tree or in any other folder set within the PATH
> variable.=20
> =20
> Thanks Juergen
> =20
> =20
> =20
> =20
> =20
> *********************************************************<?xml:namespace=
> prefix =3D o ns =3D "urn:schemas-microsoft-com:office:office" />
> J=FCrgen Bayer
> Forstliche Versuchs- und Forschungsanstalt Baden-W=FCrttemberg/VfS
> Abteilung Wald=F6kologie
> Wonnhaldestr. 4
> 79110 Freiburg
> <mailto:Juergen.Bayer at forst.bwl.de> Juergen.Bayer at forst.bwl.de
> Content-Type: text/html;
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
> <HTML><HEAD>
> <META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
> charset=3Diso-8859-1">
> <META content=3D"MSHTML 6.00.2800.1141" name=3DGENERATOR></HEAD>
> <BODY>
> <DIV><FONT face=3DArial size=3D2><SPAN class=3D926315014-09102004>Have =
> just installed=20
> grass57 and the latest cygwin release from bineary =
> installs.</SPAN></FONT></DIV>
> <DIV><FONT face=3DArial size=3D2><SPAN class=3D926315014-09102004>Get =
> it started but=20
> after displaying the first maps or when opening most dialogs boxes, I =
> get a=20
> PG.DLL is missing message from several tools (e.g. ps.map). I think I =
> had=20
> installed cygwin with almost all components.</SPAN></FONT></DIV>
> <DIV><FONT face=3DArial size=3D2><SPAN=20
> class=3D926315014-09102004></SPAN></FONT> </DIV>
> <DIV><FONT face=3DArial size=3D2><SPAN class=3D926315014-09102004>All =
> on W2K, Svp4,=20
> German release</SPAN></FONT></DIV>
> <DIV><FONT face=3DArial size=3D2><SPAN class=3D926315014-09102004>Any =
> idea what=20
> component is missing? If not: pg.dll should be located anywhere in the =
> winnt=20
> tree or in any other folder set within the PATH variable. =
> <DIV><FONT face=3DArial size=3D2><SPAN =
> class=3D926315014-09102004>Thanks=20
> Juergen</SPAN></FONT></DIV>
> <DIV><FONT face=3DArial size=3D2></FONT> </DIV>
> <DIV class=3DSection1>
> <P style=3D"MARGIN: 0cm 0cm 0pt"><SPAN=20
> style=3D"FONT-SIZE: 7.5pt; COLOR: navy; FONT-FAMILY: =
> Arial">*********************************************************</SPAN><=
> SPAN=20
> style=3D"FONT-SIZE: 10pt"><?xml:namespace prefix =3D o ns =3D=20
> "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P>
> style=3D"FONT-SIZE: 7.5pt; COLOR: navy; FONT-FAMILY: Arial">J=FCrgen=20
> Bayer</SPAN><SPAN style=3D"FONT-SIZE: 10pt"><o:p></o:p></SPAN></P>
> style=3D"FONT-SIZE: 7.5pt; COLOR: navy; FONT-FAMILY: Arial">Forstliche =
> Versuchs-=20
> und Forschungsanstalt Baden-W=FCrttemberg/VfS</SPAN><SPAN=20
> style=3D"FONT-SIZE: 7.5pt; COLOR: navy; FONT-FAMILY: Arial">Abteilung=20
> Wald=F6kologie</SPAN><SPAN style=3D"FONT-SIZE: =
> Arial">Wonnhaldestr.=20
> 4</SPAN><SPAN style=3D"FONT-SIZE: 10pt"><o:p></o:p></SPAN></P>
> style=3D"FONT-SIZE: 7.5pt; COLOR: navy; FONT-FAMILY: Arial">79110=20
> Freiburg</SPAN><SPAN style=3D"FONT-SIZE: 10pt"><o:p></o:p></SPAN></P>
> <P style=3D"MARGIN: 0cm 0cm 0pt"><SPAN style=3D"FONT-SIZE: 10pt"><A=20
> href=3D"mailto:Juergen.Bayer at forst.bwl.de"><SPAN=20
> Arial">Juergen.Bayer at forst.bwl.de</SPAN></A><o:p></o:p></SPAN></P>
> SPAN=20
> 10pt"><o:p></o:p></SPAN></P></DIV></DIV></BODY></HTML>
> ------_=_NextPart_001_01C4AE10.4CD08420--
> --__--__--
> Message: 2
> Date: Sat, 09 Oct 2004 17:50:03 +0200
> From: =?ISO-8859-1?Q?=C1d=E1m_Csaba?= <csaba at adamiroda.hu>
> Subject: Re: [winGRASS] pg.dll not found in W2K Svp4
> Hi Juergen,
>>...I get a PG.DLL is missing message ...
> I have no pure "pg.dll" in the Cygwin directory.
> There are pg_blah-blah.dlls in the /bin/ dir, but
> they belong to the PostgreSQL.
> And there is a "pq.dll" in the /bin/ (PQ.DLL).
> That's all.
> Regards,
> Csaba
> --__--__--
> Message: 3
> Date: Sun, 10 Oct 2004 01:21:11 +0200
> From: "Gerrit P. Haase" <gp at familiehaase.de>
> Organization: Esse keine toten Tiere
> Subject: [winGRASS] include winGRASS with Cygwin distribution?
> Hello,
> whoever is maintaing the Cygwin port of winGRASS, isn't there interest
> to include winGRASS as a package with the Cygwin net distribution, so
> people could use setup.exe to install wniGRASS including dependencies?
> We're also right now discussing at the Cygwin maintainer list about the
> inclusion PostGIS as an addon to the POstgreSQL package, however I don't
> now if that belongs here.
> Gerrit
> --__--__--
> Message: 4
> Date: Sat, 09 Oct 2004 18:31:24 -0600
> From: Richard Greenwood <rich at greenwoodmap.com>
> To: "Gerrit P. Haase" <gp at familiehaase.de>
> CC: mperra at petrelrob.com, wingrass at grass.itc.it
> Subject: Re: [winGRASS] problem starting grass
> Gerrit P. Haase wrote:
>>Martin Perra wrote:
>>>when I type "grass57" I get a popup titled "wish8.3.exe - unable to
>>>locate
>>>component" The message says "This application failed to start because
>>>cygwinb19.dll was not found. Re-installing the application may fix this
>>>problem"
>>>Any ideas?
>>Get a new TCL package, yours must be at least 5 years old.
>>Gerrit
> No, don't update Tcl/Tk, Grass requires a modified version of Tcl/Tk
> found at:
> http://grass.itc.it/grass57/binary/mswindows_cygwin
> download:
> xtcltk-8.3.4-CYGWIN.tar.gz
> You can use Cygwin setup to un-install any existing Cygwin version of
> Tcl/Tk, or you can use some other method to hide it. You can issue the
> command 'which wish' to see which version Grass is finding, or 'which -a
> wish' to see all versions of wish which are installed. (wish is a
> component of Tcl/Tk).
> I have no idea what's with the "cygwinb19.dll", I don't have one on my
> system.
> Rich
> Richard Greenwood
> www.greenwoodmap.com
> --__--__--
> Message: 5
> Date: Sun, 10 Oct 2004 03:17:04 +0200
> To: Richard Greenwood <rich at greenwoodmap.com>
>>>>locate
>>>>problem"
>>>>Any ideas?
>>>Gerrit
>>found at:
>>download:
>>system.
> If this TCL/TK depends on a 5 years old version of Cygwin, then good
> night, I'm sure that there are more than one ports of recent TCL
> packages to recent Cygwin versions out there in the web, so why should
> one use a beta version which b19 is (that was the beta before beta20).
> We have five years later and Cygwin is at version 1.5, no beta, more
> stable IMO.
> In the document at the website you quopted is stated:
> "Prerequisites:
> - Cygwin, latest release,"
> No word about b19, I assume the TCL package is broken, ask the maintainer.
> And could you tell me who is this maintainer and what is the difference
> with this TCL package?
> Gerrit
> --__--__--
> Message: 6
> Date: Sun, 10 Oct 2004 10:37:50 +0200
> CC: Richard Greenwood <rich at greenwoodmap.com>, mperra at petrelrob.com
>>"Prerequisites:
> Is it eventually the MySQL client which is requireing cygwinB19?
> You may fetch my MySQL package then which is compiled against recent
> Cygwin DLL:
> http://anfaenger.de/cygwin/cygwin-1.5/mysql/mysql-4.0.17-pc-cygwin-i686-1.ta
> r.bz2
> There is the server included in this huge package, just move mysql.exe
> and the cygmysqlclient-x.dll to a directory in your PATH (e.g.
> /usr/local/bin).
> Gerrit
> --__--__--
> winGRASS at grass.itc.it
> End of winGRASS Digest
Richard Greenwood
More information about the grass-windows
