[winGRASS] NVIZ on cygwin
Huidae Cho
grass4u at gmail.com
Mon Oct 25 00:47:07 EDT 2004
You can download it at http://geni.ath.cx/nviz.html
On Sun, 24 Oct 2004 21:09:16 -0600, Richard Greenwood
<richard.greenwood at gmail.com> wrote:
> Huidae Cho wrote:
> > Hi list,
> > I've upgraded to grass 5.7 and found that NVIZ won't work any more
> > even though I copied the pre-compiled NVWISH2.2 which is available at
> > the wingrass page. I compiled it with xtcltk, not cygwin version, but
> > it failed to run with segmentation fault.
> > I decided to rebuild whole tcltk from its sources and not to use
> > windows code but unix directory. With little modification, I succeeded
> > to compile both tcltk and NVIZ and so far, I don't have any problem.
> > Even better is that I can resize an NVIZ window without having to run
> > X in full mode (I couldn't do it with the pre-compiled NVWISH2.2).
> > Anyway, attachments are patch files for tcl/tk 8.4.7.
> > 1. download tcl8.4.7-src.tar.gz and tk8.4.7-src.tar.gz
> > 2. tar xvfz tcl8.4.7-src.tar.gz
> > patch -p 0 < tcl8.4.7-cygwin.patch
> > cd tcl8.4.7/unix
> > ./configure
> > make
> > make install
> > 3. tar xvfz tk8.4.7-src.tar.gz
> > patch -p 0 < tk8.4.7-cygwin.patch
> > cd tk8.4.7/unix
> > ./configure
> > make
> > make install
> > Hope you enjoy!
> > Huidae Cho
> Nice work! Thanks for sharing. Maybe your binaries should replace the
> ones currently being distributed.
> Richard Greenwood
> www.greenwoodmap.com
More information about the grass-windows
