[winGRASS] pq.dll
Richard Greenwood
richard.greenwood at gmail.com
Wed Oct 27 09:19:46 EDT 2004
On Wed, 27 Oct 2004 14:11:25 +0800, Helmut Muenzing <hmc at sflu.com> wrote:
> Hello
> I am running GRASS 5.3 with X-Windows using the precompiled binaries.
> The program is generally working fine. However, on starting NVIZ I am
> getting the error message:
> "NVWISH2.2 – Unable to Locate Component
> This application has failed to start because pq.dll was not found.
> Re-installing the application may fix this problem."
> Where is pq.dll supposed to live? Where can I get it from?
> Regards
> Helmut Muenzing
pq.dll is a PostgreSQL library. I suggest that you run Cygwin setup
and install PostgreSQL on your computer. It is not strictly required
by nviz, but it sounds like nviz was compiled with PostgreSQL
dependencies. pq.dll should be in /bin (setup will put it there).
Rich
Richard Greenwood
www.greenwoodmap.com
More information about the grass-windows
