[winGRASS] NVIZ on Grass5.3 and 5.7 using binaries
Huidae Cho
grass4u at gmail.com
Thu Oct 28 21:47:23 EDT 2004
On Fri, 29 Oct 2004 09:00:52 +0800, Helmut Muenzing <hmc at sflu.com> wrote:
> Hello list
> Recently I installed GRASS 5.7 using the binaries offered at the site. But
> even though I used the tcltk provided by Huidae Cho I could not run NVIZ. I
> think the binaries are just a bit outdated and thus I shall wait until new
> binaries will be available. Any idea when that may happen?
Did you try NVWISH2.2.gz also at http://geni.ath.cx/nviz.html ?
Actually, I compiled these files with the latest CVS version, so it
can happen that you cannot run it in your environment; it may depend
on the pre-compiled 5.7 package. But I think it doesn't matter.
If you didn't install NVWISH2.2.gz, just try this:
gzip -d NVWISH2.2.gz
cp -f NVWISH2.2 /usr/local/grass-5.7/etc/nviz2.2
Hope this helps.
Regards,
Huidae Cho
> Now I was able to run NVIZ on GRASS 5.3 (also with the binaries provided),
> but there are strange things happening:
> NVIZ opens well but with the Control Window shrunk to the blue top only. It
> cannot be re-sized, though all other windows behave normally. The Control
> Window can only be used in full-screen mode.
> Surfaces can be displayed very well and behave according to the controls.
> However vector files do not show up at all or sporadically only. (I could
> not find a logic connection between the sporadical appearance and the
> control settings.)
> Can anyone enlighten me?
> By the way, I am using CYGWIN's X-Window opened with startxwin.bat.
> Regards
> Helmut Muenzing
> hmc at sflu.com
More information about the grass-windows
