[winGRASS] NVIZ on Grass5.3 and 5.7 using binaries
    Huidae Cho
    grass4u at gmail.com
    Fri Oct 29 03:39:51 EDT 2004
I see what's the problem. Most of my grass libraries are *.dll
but in the binary package these are in *.a format.
Hmm... I didn't know it. I don't know why the winGRASS team
built these as static libraries.
Anyway, I'll make static libraries sometime in this weekend and
package another binary distribution.
See you soon. :-)
Huidae Cho
On Fri, 29 Oct 2004 15:20:21 +0800, Helmut Muenzing <hmc at sflu.com> wrote:
> Thanks. You are right. IE is doing funny things to those files. Expanding them,
> but leaving the ".gz"!
> Well, I copied your NVWISH2.2 to the correct location and run GRASS 5.7. When I
> opened NVIZ I got the following error message:
> "... libgrass-gis.dll was not found ..." and the X-window console showed the
> attached screenshot.
> Where can I get libgrass-gis.dll?
> Sorry for bugging you all the time.
> Helmut Muenzing
> hmc at sflu.com
> -----Original Message-----
> From: Huidae Cho [mailto:grass4u at gmail.com]
> Sent: Friday, 29 October, 2004 14:09
> To: hmc at sflu.com
> Subject: Re: [winGRASS] NVIZ on Grass5.3 and 5.7 using binaries
> Do you use IE? Then IE usually uncompress gzipped file on-the-fly, so
> the file may be already executable one. Try this: "file NVWISH2.2.gz".
> If it says "MS Windows PE...", then that's it. Just "cp NVWISH2.2.gz
> /usr/local/grass57/etc/nviz/NVWISH2.2"
> Just in case, I attached the file.
> Huidae Cho
> On Fri, 29 Oct 2004 13:37:14 +0800, Helmut Muenzing <hmc at sflu.com> wrote:
> > Hi
> > Thanks for the advice. I downloaded NVWISH2.2.gz but when I run gzip I got the
> > error message: "gzip: NVWISH2.2.gz not in gzip format"
> > I did probably something stupid. But what?
> > Regards
> > Helmut Muenzing
> > hmc at sflu.com
> > Sent: Friday, 29 October, 2004 09:47
> > To: hmc at sflu.com
> > Cc: wingrass at grass.itc.it
> > Hi,
> > On Fri, 29 Oct 2004 09:00:52 +0800, Helmut Muenzing <hmc at sflu.com> wrote:
> > > Hello list
> > > Recently I installed GRASS 5.7 using the binaries offered at the site. But
> > > even though I used the tcltk provided by Huidae Cho I could not run NVIZ. I
> > > think the binaries are just a bit outdated and thus I shall wait until new
> > > binaries will be available. Any idea when that may happen?
> > Did you try NVWISH2.2.gz also at http://geni.ath.cx/nviz.html ?
> > Actually, I compiled these files with the latest CVS version, so it
> > can happen that you cannot run it in your environment; it may depend
> > on the pre-compiled 5.7 package. But I think it doesn't matter.
> > If you didn't install NVWISH2.2.gz, just try this:
> > gzip -d NVWISH2.2.gz
> > cp -f NVWISH2.2 /usr/local/grass-5.7/etc/nviz2.2
> > Hope this helps.
> > Regards,
> > Huidae Cho
> > > Now I was able to run NVIZ on GRASS 5.3 (also with the binaries provided),
> > > but there are strange things happening:
> > > NVIZ opens well but with the Control Window shrunk to the blue top only. It
> > > cannot be re-sized, though all other windows behave normally. The Control
> > > Window can only be used in full-screen mode.
> > > Surfaces can be displayed very well and behave according to the controls.
> > > However vector files do not show up at all or sporadically only. (I could
> > > not find a logic connection between the sporadical appearance and the
> > > control settings.)
> > > Can anyone enlighten me?
> > > By the way, I am using CYGWIN's X-Window opened with startxwin.bat.
> > > Regards
> > > Helmut Muenzing
> > > hmc at sflu.com
More information about the grass-windows
