[winGRASS]  impure ptr error message with cygwinx
    Huidae Cho
    grass4u at gmail.com
    Fri Jan 14 18:28:52 EST 2005
You mean you installed CygwinX April 2003 version? If so, I recommend
you to install the latest cygwin version (non X packages + X packages)
because cygwin X has changed to x.org from XFree86 recently.
And I want to know if this problem comes from my distribution or cygwin,
so could anyone test this?
Thank you.
Huidae Cho
On Sat, Jan 15, 2005 at 12:00:02AM +0100, info at thomas-reinfelder.de wrote:
> Hi everybody,
> I have a problem with CygwinX.
> I tried to install the new GRASS 6.0 beta1 binary distribution for
> Cygwin. Installation was ok but then ...
> When I want to create a new location I get an error message:
> In German:
> set_data.exe - Einsprungpunkt nicht gefunden
> Der Prozedureinsprungpunkt _impure_ptr wurde in der DLL cygwin1.dll
> nicht gefunde
> In English:
> "the jump-in-point is not found in cygwin1.dll" sorry for this english
> but....
> I have installed the whole CygwinX (without tcltk), it is Cygwin version
> from last year (April - I think)...
> What can I do????
> thomas....
> Thomas Reinfelder
> Don-Bosco Str. 5
> 96047 Bamberg
> email: info at thomas-reinfelder.de
> http://www.thomas-reinfelder.de
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows
