[winGRASS] GUI trouble in WINGRASS
David Hollema
dhollema at UnitedPower.com
Mon Jul 11 12:23:56 EDT 2005
I've installed cygwin, wingrass 6.0 etc and when I run grass60.bat, I the
data selection dialog does not open. If I open a shell and run the batch
file,
"Application initialization failed: no display name and no $DISPLAY
environment variable
Cleaning up temporary files......
Starting GRASS ...
WARNING: It appears that the X Windows system is not active. A graphical
based user interface is not supported. Switching to text based interface
mode. Hit RETURN to continue."
Cygwin/X Server is open in the system tray with 0 clients connected. What
do I do?
David
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20050711/785e173a/attachment.html
More information about the grass-windows
