[winGRASS] GUI trouble in WINGRASS
Richard Greenwood richard.greenwood at gmail.com
Mon Jul 11 19:16:43 EDT 2005
On 7/11/05, David Hollema <dhollema at unitedpower.com> wrote:
> I've installed cygwin, wingrass 6.0 etc and when I run grass60.bat, I the
> data selection dialog does not open.  If I open a shell and run the batch
> file,
> "Application initialization failed: no display name and no $DISPLAY
> environment variable
> Cleaning up temporary files……
> Starting GRASS …
> WARNING: It appears that the X Windows system is not active.  A graphical
> based user interface is not supported.  Switching to text based interface
> mode.  Hit RETURN to continue."
Can you open the Cygwin Bash shell and type:
   startx
and get a X-Windows Bash shell running?
If not, type:
   export DISPLAY=127.0.0.1:0
then try
   startx
Then from the X-Windows Bash shell:
   grass60
Richard Greenwood
www.greenwoodmap.com
More information about the grass-windows mailing list
