[winGRASS] MrSID into wingrass
Richard Greenwood
richard.greenwood at gmail.com
Sat Jul 16 09:37:16 EDT 2005
On 7/14/05, Gerry James <gjames at bgcengineering.ca> wrote:
> I have had difficulty importing MrSID files into wingrass. I have no
> problem with geotiff or other raster formats. When I looked up the
> supported formats in the 6.1 manual I found Multi-resolution Seamless
> Image Database (MrSID) listed. Is this only available in the Linux
> version or is there a patch.
> Any input would be greatly appreciated.
> Thanks
> Gerry
> Gerry James, Geomatics Manager
> BGC Engineering Inc.
> Geomatics and Information Management Group
> 604.684.5900 x.126
I assume you are using r.in.gdal? Gdal can be compiled to support
reading MrSID format, but I do not know if the current cygwin grass
binary distribution of gdal includes MrSID support. You could:
1. build cygwin grass/gdal with MrSID - pretty hard.
2. build standalone gdal w/ MrSID support - medium hard, requires MS VC
3. find a gdal binary w/ MrSID support - I'm not sure what's available.
4. use a commandline tool available from the lizardtech wed site
called "mrsiddecode.exe" which can be used to batch process multiple
sid file to tiffs. This is brute force but easy.
HTH,
Rich
Richard Greenwood
www.greenwoodmap.com
More information about the grass-windows
