[winGRASS] Getting started with Wingrass ...
    Anna Forrest
    hric at ozemail.com.au
    Wed Jul 27 02:07:50 EDT 2005
Greetings all.  I have installed WinGrass from the ISO downloaded at
http://jrshelby.com/grass/install-cd.htm.  I had no problems installing
onto Win2k, and I even managed to launch the GRASS window once with the
grass61.bat file, but usually when I run grass61.bat I don't see
anything happen at all.  I do get the 'x' icon on my start bar, but no
Grass window.  I've tried running the .bat file both from the command
prompt and from windows explorer with no difference.  I'm very new to
this - can anyone please help?
Regards
Anna Forrest
Herbert Resource Information Centre
PO Box 6000
Ingham QLD 4850
Ph: (07) 4776 0007
Fax: (07) 4776 3077
Email: hric at ozemail.com.au
http://www.hric.org.au
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20050727/3950daed/attachment.html
More information about the grass-windows
