[winGRASS] set home directory
Martin Perra mperra at petrelrob.com
Fri Mar 4 17:23:45 EST 2005
I need to change my home directory in cygwin, as it is defaulting to my
windows network home, and I do not want it to go to the network drive.  Is
there an easy way to do this?  When I first run Cygwin, it says I need to
run the mkuser command and something else (it only showed up the first time
I started cygwin).  Does this have something to do with it?
Martin
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20050304/cc27afc8/attachment.html
More information about the grass-windows mailing list
