AW: [winGRASS] GRASS_HTML_BROWSER
Marco Lechner
marco.lechner at geographie.uni-freiburg.de
Fri Mar 11 05:23:56 EST 2005
Hi Scott,
if you used the CygwinGRASS-CD from
https://www.geographie.uni-freiburg.de/~mlechner/CygwinGRASS/ to install
your GRASS on M$ this problem is normal. (By the way the CD is not created
by Huidae Cho, it's created by Marco Lechner - that's me ;-)
theres no Browserinstallation (konqueror) included in the
Cygwin-Installation (because most M$-Machines come with a browser.
Read this first:
http://grass.itc.it/pipermail/wingrass/2004-December/000643.html
afterwards you could create links like written down there:
ln -s '/cygdrive/c/Programme/Mozilla Firefox/firefox.exe' /bin/firefox.exe
or
ln -s '/cygdrive/c/Programme/Internet Explorer/iexplore.exe'
/bin/iexplore.exe
if you create a link like this GRASS starts firefox from within the
GRASS-environment withput setting GRASS_HTML_BROWSER:
ln -s '/cygdrive/c/Programme/Mozilla Firefox/firefox.exe' /bin/konqueror or
ln -s '/cygdrive/c/Programme/Internet Explorer/iexplore.exe' /bin/konqueror
of course you have to change the path if your Browser-executables are in
different locations
The problem is, that the command created by g.manual is i.e.:
GRASS 6.0.cvs:~ >konqueror "/usr/local/grass6.0.cvs/docs/html/index.html" ->
couldn't display
the result is attached as an screenshot.
The command that should be generated within Cygwin should be one of those:
GRASS 6.0.cvs:~ >iexplore
"c:/cygwin/usr/local/grass6.0.cvs/docs/html/index.html" O.K.
GRASS 6.0.cvs:~ > iexplore
"c:\cygwin\usr\local\grass6.0.cvs\docs\html\index.html" O.K.
GRASS 6.0.cvs:~ > firefox
The IE handles \ and / firefox needs / otherwise firefox creates an
errormessage or opens from within GRASS with displaying the default
startup-page.
"c:/cygwin/usr/local/grass6.0.cvs/docs/html/index.html" -> ERROR
Does anybody have time to add a Cygwin-hack into g.manual, ... ??
Marco
Marco Lechner
office:
Department of Physische Geographie
University of Freiburg
Werderring 4
D-79085 Freiburg
Germany
phone +49 (0)761 / 203-3548
email marco.lechner at geographie.uni-freiburg.de
-----Ursprungliche Nachricht-----
Von: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]Im
Auftrag von Scott
Gesendet: Donnerstag, 10. Marz 2005 18:00
An: wingrass at grass.itc.it
Betreff: [winGRASS] GRASS_HTML_BROWSER
I am having a problem viewing the help documents within grass60
(CygwinGRASS_CD-0.2.iso installation from Huidae Cho). No matter what I set
the GRASS_HTML_BROWSER variable to using g.gisenv, it still gives the same
error message (included below). It could be that I just don't know what to
set the variable to. I tried the full path to the executable files for the
browsers (mozilla firefox and netscape) and then just the names but with no
success. I also tried a couple of phrases I knew wouldn't work but still the
same message.
Any suggestions?
Thanks in advance.
Scott Shouse
"Error: couldn't execute "knonqueror": no such file or directory"
couldn't execute "konqueror": no such file or directory
while executing
"exec $env(GRASS_HTML_BROWSER) $env(GISBASE)/docs/html/index.html & "
invoked from within
".#menubar.#menubar#menu8 invoke active"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke active]"
(procedure "tk::MenuInvoke" line 47)
invoked from within
"tk::MenuInvoke .#menubar.#menubar#menu8 1"
(command bound to event)
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20050311/36b2a143/attachment.html
More information about the grass-windows
