AW: [winGRASS] GRASS 6.0.0 release - libgrass*.6.1.cvs.dll not found - reason!
Marco Lechner
marco.lechner at geographie.uni-freiburg.de
Thu Mar 17 02:51:53 EST 2005
Hi Cho,
does this mean, it is not possible to use 6.0.0 and 6.1.cvs parallel on one
Cygwin-computer ? And you have to use the right gdal-grass for the
GRASS-Version you are using?
If this is true it explains a few problems I had.
Anyway I produced the CygwinGRASS-0.3.1 wich uses the current grass-6.1.cvs
as default and 6.0.0 can be installed alternatively (by modifying the
Packagelist)
Well it also creates the grass61.bat and a ln -s to the IE, if it is
installed under C:\programme\Internet Explorer\iexplore.exe (germen
version!) - I will put this in an postinstallscript wich assures that the
softlink is set to an existing iexplore.exe (but this will take up to 2
weeks, because I'm very busy.
This changes are very Cygwin-special, so i think we can not include them in
the GRASS-CVS or?
Marco
Marco Lechner
dienstlich:
Institut fur Physische Geographie
Uni Freiburg
Werderring 4
79085 Freiburg
Fon 0761 / 203-3548
Mail marco.lechner at geographie.uni-freiburg.de
-----Ursprungliche Nachricht-----
Von: Huidae Cho [mailto:grass4u at gmail.com]
Gesendet: Mittwoch, 16. Marz 2005 19:14
An: Marco Lechner
Betreff: Re: [winGRASS] GRASS 6.0.0 release - libgrass*.6.1.cvs.dll not
found
That's because of the GDAL library. To support r.out.gdal, I had to
compile my gdal library with grass support and it means gdal is linked
to a certain version of the grass library.
Download the corresponding file:
for 6.0.0, grass/gdal-grass6.0.0-1.2.3-1.tar.bz2
for 6.0.cvs grass/gdal-grass6.0.cvs-1.2.3-1.tar.bz2
for 6.1.cvs grass/gdal-grass6.1.cvs-1.2.3-1.tar.bz2
Huidae Cho
On Wed, Mar 16, 2005 at 03:59:30PM +0100, Marco Lechner wrote:
> Hi Cho, and wingrass-list
> I have a bug in 6.0.0 wich I can not reproduce. Well, if I install
> grass-6.0.0 (doesn't make a difference if I compile it by myself or if I
use
> the Cygwin-Ibstaller and include your Cygwin-Mirror - I also tried it on a
> fresh mashine)
> When I start GRASS-6.0.0 after the Installation it gives the errormessage
> (see attached file): "The Application couldn't be started, becaous
> libgrass_gis.6.1.cvs.dll is not found" Of course it isn't installed in the
> 6.0.0-Version because the libraries are named libgrass*.6.0.0.dll.
> this problem started with Version 6.0.0beta2 (I always had to set the
> ../include/VERSION file to 6.0.cvs. I thought it's because 6.0.cvs was the
> Version before 6.0.0beta2, but the problem still goes on I couldn't
realize
> how to fix it.
> Marco
> P.S. I tried to make the new CygwinGRASS-CD including 6.0.0 and 6.1.cvs -
> well 6.1.cvs works without problems but the described problems occur with
> Version 6.0.0
> Marco Lechner
> office:
> Department of Physische Geographie
> University of Freiburg
> Werderring 4
> D-79085 Freiburg
> Germany
> phone +49 (0)761 / 203-3548
> email marco.lechner at geographie.uni-freiburg.de
More information about the grass-windows
