AW: [winGRASS] GRASS 6.0.0 release - libgrass*.6.1.cvs.dll not found - reason!
Glynn Clements
glynn at gclements.plus.com
Thu Mar 17 15:09:11 EST 2005
Marco Lechner wrote:
> does this mean, it is not possible to use 6.0.0 and 6.1.cvs parallel on one
> Cygwin-computer?
Not entirely. You would either need to build GDAL without GRASS
support, or build separate copies of GDAL for 6.0 and 6.1, and build
each version of GRASS with the correct version of GDAL.
If GDAL is built as a DLL, the DLL needs to go into the "bin"
directory for the corresponding version of GRASS.
> And you have to use the right gdal-grass for the
> GRASS-Version you are using?
Yes.
More information about the grass-windows
