AW: AW: [winGRASS] GRASS 6.0.0 release - libgrass*.6.1.cvs.dll not found - reason!
    Marco Lechner
    marco.lechner at geographie.uni-freiburg.de
    Thu Mar 17 18:34:19 EST 2005
thanks Glynn,
but the problem was to use the precompiled binaries from Cho to include them
into an CygwinGRASS-Install-CD. in this case the solution would be to create
new precompiled binaries that use different paths to GDAL an to create
different GDAL -packages (in different paths) wich are used by the
precompiled binaries.
This means: for the CygwinGRASS- and the XliveGRASS-project we have to add
only one Version (current: 6.1.cvs) as default -installation to make it work
and create dependencies to the coresponding GDAL-package
Marco
P.S. Xlivegrass-0.3.1 is out :
https://www.geographie.uni-freiburg.de/~mlechenr/xlivegrass - run
GRAS-6.1.cvs from CD without installing the program on M$ Windows.
Marco Lechner
dienstlich:
Institut fur Physische Geographie
Uni Freiburg
Werderring 4
79085 Freiburg
Fon 0761 / 203-3548
Mail marco.lechner at geographie.uni-freiburg.de
-----Ursprungliche Nachricht-----
Von: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]Im
Auftrag von Glynn Clements
Gesendet: Donnerstag, 17. Marz 2005 21:09
An: Marco Lechner
Cc: Huidae Cho; Wingrass
Betreff: Re: AW: [winGRASS] GRASS 6.0.0 release - libgrass*.6.1.cvs.dll
not found - reason!
Marco Lechner wrote:
> does this mean, it is not possible to use 6.0.0 and 6.1.cvs parallel on
one
> Cygwin-computer?
Not entirely. You would either need to build GDAL without GRASS
support, or build separate copies of GDAL for 6.0 and 6.1, and build
each version of GRASS with the correct version of GDAL.
If GDAL is built as a DLL, the DLL needs to go into the "bin"
directory for the corresponding version of GRASS.
> And you have to use the right gdal-grass for the
> GRASS-Version you are using?
Yes.
winGRASS mailing list
winGRASS at grass.itc.it
http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows
