[winGRASS] Re: [GRASSLIST:6205] RE: V.in.ogr and coor file bytes excess
    Glynn Clements
    glynn at gclements.plus.com
    Fri Mar 18 15:33:43 EST 2005
Hamish wrote:
> > > When importing shapefiles with areas in the graphical
> > > interface, it hangs
> > The bug is reported by Maciek Sieczka before, look at
> > http://grass.itc.it/pipermail/grass5/2005-January/017090.html.
> > I guess it is not taken care of after that.
> there is non-parser code between the G_gisinit() and G_parser() calls in
> vector/v.in.ogr/main.c. Maybe this has something to do with it?
It shouldn't be doing that, but I don't think that's the problem here.
If the program writes anything to stdout or stderr, d.m should report
an error without displaying the options dialog.
More information about the grass-windows
