[winGRASS] Navigating drives and directories
Tyler Mitchell tjm at timberline.ca
Fri Mar 18 18:43:33 EST 2005
Hi Larry,
Cygwin uses Unix style drive/directory structures.  If you need to refer
to a specific Windows drive letter you can do so two ways.  1) by going
to the /cygdrive/ folder off the root, where you'll see your drive
letters listed.  2) Or you use the drive letter with a slash after it
instead of the typical backslash (or do I have that mixed up?).
So either of these should work in Cygwin:
/cygdrive/d/shapedata
or
d:/shapedata
Hope that helps - welcome aboard and welcome to the new world of spatial
analysis, there is some exciting stuff going on with these great tools
Tyler
Larry Layne wrote:
> After successfully installing cygwin and GRASS 6.0.0 per the
> instructions found at http://geni.ath.cx/grass.html I'm now trying to
> begin learning the GRASS software, and am new to this mailing list. As a
> short preface, I have been an ESRI software user (Arc/Info, ArcGIS,
> ArcView 3.x) for 10 years, primarily on M$ OSes. Currently I use
> computers running 2000 SP4 and XP SP1.
> I installed cygwin according to the above instructions, specifically in
> c:\cygwin. In GRASS, I specified the database to be in
> c:\cygwin\home\laynent\grass_data with the LOCATION in newLocation. From
> the "GRASS 6.0.0 Data Selection" window I can navigate to the /home
> directory (= c:\cygwin\home) but no further (such as to the c:\
> directory). Likewise if I want to import data, such as a shapefile, in
> the "v.in.ogr" window I cannot navigate further than the c:\cygwin
> directory. That is, if my shapefile data is in the drive and directory
> d:\shapedata\year2000 it appears that I would have to copy any
> shapefiles in this directory into at least the c:\cygwin directory.
> Is GRASS limited to working only within the c:\cygwin directory and its
> subdirectories, or is there some setting that can be made so that I can
> navigate to other drives and directories from within GRASS 6.0.0?
> If there are help pages/manuals or messages in the mailing list that
> deal with this issue, could you please direct me to them.
> Thanks for any assistance.
> Larry
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows mailing list
