[winGRASS] Total Newb -- Can't see PERMANENT
Sun Aug 27 14:46:10 EDT 2006
Eric Vey wrote:
> mapset in Spearfish 60. Running 6.1. I can make a mapset in Spearfish60,
> though and I can create a new location.
> The PERMANENT mapset is in the right place and is right next to the test
> mapset I made in the folder.
>  I have searched and searched, but I don't see anyone else having this
> trouble, so maybe I messed up the installation? I feel so dumb that I
> can't even open a fileset. How will I ever learn to import data?
The mapsets list in the startup dialog only lists the mapsets which
you can select as your current mapset, i.e. those for which you own
the mapset directory.
You shouldn't normally select the PERMANENT mapset as your current
mapset.
More information about the grass-windows mailing list
